Protocol Number 0x27
Location report supplementary item 0x57
armed.status
Armed/disarmed status
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0xE1,
NBR Command,
V1 Command
Message ID 0x0202,
Message ID 0x0203,
Location report supplementary item 0x82,
Location report supplementary item 0x33
Message ID 0x0202,
Message ID 0x0203
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0xA0
Location report supplementary item 0x84
Location report supplementary item 0x83
Location report supplementary item 0x8E
Location report supplementary item 0x81
Location report supplementary item 0x85
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x86
Location report supplementary item 0x88
Location report supplementary item 0x87
can.recharge.mileage
Location report supplementary item 0x8D
Location report supplementary item 0x89
Location report supplementary item 0x8C
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x80
city.id
ID of device's home city"
NBR Command,
V1 Command,
V19 Command
Location report supplementary item 0x51
Location report supplementary item 0x57,
Message ID 0x0202,
Message ID 0x0203,
Message ID 0x0202,
Message ID 0x0203,
NBR Command,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203
glonass.position.satellites
Location report supplementary item 0x34
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x32
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x9F,
NBR Command,
V1 Command
NBR Command,
V1 Command
NBR Command,
V1 Command
NBR Command,
V1 Command
NBR Command,
Protocol Number 0x28
Location report supplementary item 0x30,
Location report supplementary item 0xCC,
V19 Command
main.power.low.status
Main power low status
Message ID 0x0202,
Message ID 0x0203
manufacturer.code
Device manufacturer code"
manufacturer.device.code
NBR Command,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203
network.type.enum
Transmission channel
Location report supplementary item 0xE2
Message ID 0x0202,
Message ID 0x0203,
NBR Command,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203
Message ID 0x0202,
Message ID 0x0203,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203,
V1 Command,
V19 Command
Location report supplementary item 0x31
Message ID 0x0202,
Message ID 0x0203,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203,
V1 Command,
V19 Command
NBR Command,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203
province.id
ID of device's home province"
NBR Command,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203
Message ID 0x0202,
Message ID 0x0203,
NBR Command,
V1 Command,
V19 Command
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x94
Location report supplementary item 0x93
Location report supplementary item 0x8F
trip.harsh.braking.number
Location report supplementary item 0x90
trip.harsh.cornering.number
Location report supplementary item 0x91
Location report supplementary item 0x97
Location report supplementary item 0x95
Location report supplementary item 0x92
trip.overspeeding.number
Location report supplementary item 0x96
Message ID 0x0202,
Message ID 0x0203
vehicle.load.state
Vehicle load state
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x01,
NBR Command,
V1 Command,
V19 Command
NBR Command,
V1 Command,
V19 Command
Location report supplementary item 0x8B,
Message ID 0x0202,
Message ID 0x0203,
NBR Command,
V1 Command,
V19 Command
