Mielta M7
Mielta M7 is a functional and reliable GPS tracking device with 2 SIM slots, 4 universal ports, voice support, 16 MB black box and more working over Wialon IPS protocol. The device features RS-485, RS-232, 1-Wire, and CAN interfaces out of the box, built-in Li-Pol battery, and an SD card slot. USB 2.0 and Bluetooth 3.0 make configuration of the tracker quick and convenient.
Parameters (55)
Mielta M7
Flespi parses telemetry data from your Mielta M7 into a standardized JSON and lets you send commands to Mielta M7 via API.
    "device.type.id": "Mielta M7",
    "protocol.id": "wialon-ips"
How to send commands to Mielta M7?
field 'accelerometer'
absolute.deceleration
field 'accel_res'
#B,
#D
field 'SOS'
field 'battery'
field 'pwr_int'
field 'axis_weight'
field 'cool_temp'
field 'engine_temp'
field 'fuel_volume'
#B,
#D
#B,
#D
#M
field 'engine operation',
field 'ign'
field 'engine_hours'
engine.oil.pressure
Engine oil pressure
field 'oil_pressure'
field 'engine rpm',
field 'engine_rpm'
field 'pwr_ext'
field 'fuel_consumption'
field 'fuel_level'
field 'fuel level'
field 'cell_id',
field 'gsm_cell'
field 'lac'
field 'mcc'
field 'mnc'
field 'hw_cfg_in_roaming'
field 'gsm'
#B,
#D,
field 'avl_driver',
field 'ibutton'
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
field 'hdop'
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
#SD
#B,
#D,
#SD
field 'hw_cfg_protocol_version'
field 'sf_ver'
field 'taho_speed'
#B,
#D,
#SD
touch.memory.id
Touch Memory Key ID
field 'touch_key'
field 'mileage'
field 'accel_x'
field 'accel_y'
field 'accel_z'
The command is used to send custom messages to the device. It allows to implement additional features necessary for the controller. is added automatically
message: Text of the message
Send custom message command
{"message":"Text of the message"}
Text message
text_msg
Send text message to device
message: Text message content
Send text message
{"message":"this is message text"}
