SelectCam M8
SelectCam M8 is an AI-enhanced 4G mobile DVR for fleet vehicles, providing up to 8 channels of Full HD recording and optional 360° monitoring. It features integrated GPS tracking, real-time 4G video streaming, forward ADAS, driver-facing DMS, and blind spot pedestrian detection for proactive safety. The rugged, industrial-grade design with enhanced cooling ensures reliable operation in demanding environments. Rich interfaces including RS232, RS485, CANBus, and GPIO support various peripherals, while encrypted dual-stream recording with SSD or dual-SD redundancy secures and protects critical video data.
Parameters (164)
Settings (27)
Commands (8)
SelectCam M8
Flespi parses telemetry data from your SelectCam M8 into a standardized JSON and lets you send commands to SelectCam M8 via API.
    "device.type.id": "SelectCam M8",
    "protocol.id": "selectcam"
How to send commands to SelectCam M8?
Additional info ID 0x64
Additional info ID 0x64,
Additional info ID 0x67
adas.blindspot.side
Alarm/Event type 3 of Additional info ID 0x64,
Alarm/Event type 8 of Additional info ID 0x64
Alarm/Event type 0x10 of Additional info ID 0x64,
Additional info ID 0x65,
Additional info ID 0x67,
Additional info ID 0x70,
Message ID 0x1212
brake.status
Brake status
Additional info ID 0xE1
Additional info ID 0xE5
Additional info ID 0xE7
Additional info ID 0xF0
Additional info ID 0xEA
Additional info ID 0xE9
Additional info ID 0xE4
Additional info ID 0xF3
Additional info ID 0xEC
Additional info ID 0xE8
Additional info ID 0xEB
Additional info ID 0xE3
Additional info ID 0xE2
Additional info ID 0xED
Additional info ID 0x25,
Additional info ID 0xEE
can.left.steering.status
Additional info ID 0xF7
Additional info ID 0xEF
Additional info ID 0xE6
can.right.steering.status
Additional info ID 0xF5
Additional info ID 0xF6
Additional info ID 0xF2
Additional info ID 0xF1
Additional info ID 0xF4
device.mode
Device working mode code
Additional info ID 0xFE
Alarm/Event type 0x0C of Additional info ID 0x65,
Alarm/Event type 0x0D of Additional info ID 0x65
dsm.fatigue.degree
Alarm/Event type 0x12 of Additional info ID 0x65,
Additional info ID 0x04,
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
Additional info ID 0xF8
Additional info ID 0xFA
Additional info ID 0xFE,
Message ID 0x0704
Message ID 0x1212
Additional info ID 0xF9,
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
ACC off GPS interval
acc_off_gps_interval
sleep_enable: Sleep enable
ACC off shutdown delay
acc_off_shutdown_delay
delay: Delay
ACC off timed power-on
acc_off_timed_power_on
ADAS alarm
adas_alarm
Enable or disable an ADAS (Advanced Driver Assistance System) alarm.
alarm_type: Alarm type
username: Username
Camera resolution
camera_resolution
Set camera resolution for a specific channel. DC10: CH2-CH3 must use the same resolution. DC20: CH3-CH6 must use the same resolution. M8: CH5-CH8 must use the same resolution.
channel: Channel
resolution: Resolution
DMS alarm
dms_alarm
Enable or disable a DMS (Driver Monitoring System) alarm.
DMS Camera Obstructed
dms_camera_obstructed
DMS alarm parameters. Changing the algorithm channel, working speed or event resolutions restarts the device.
channel: Algorithm channel
image_count: Event image count
level1_alert: Level 1 alert
level2_alert: Level 2 alert
level2_speed: Level 2 alert speed
working_speed: Working speed
alert_interval: Alert trigger interval
detection_time: Detection time
image_interval: Event image interval
sound_interval: Alert sound interval
video_duration: Event video length
upload_interval: Event upload interval
image_resolution: Event image resolution
video_resolution: Event video resolution
level1_attachment: Level 1 attachment upload
level2_attachment: Level 2 attachment upload
DMS Driver Distraction
dms_distraction
DMS Fatigue Detection
dms_fatigue
DMS No Driver Detected
dms_no_driver
DMS Driver Phone Use
dms_phone
DMS Seat Belt Non-Fastened
dms_seat_belt
DMS Driver Smoking
dms_smoking
Driver seat
driver_seat
Set the driver seat side (left-hand or right-hand drive).
side: Side
Daylight saving time
dst
Exit demo mode
exit_demo_mode
Switch the speed source back to GPS after testing the device in demo mode.
Terminal factory reset
factory_reset
Heartbeat interval
heartbeat
Highest speed
highest_speed
Overspeed duration
overspeed_duration
Recording
recording
Enable or disable recording for a specific channel and stream type.
channel: Channel
stream_type: Stream type
Terminal reset
Server
address: Server address
tcp_port: TCP port
Timed photo
timed_photo
Periodic photos taken by the device on camera channels 1-5.
ch1: CH1 enabled
ch2: CH2 enabled
ch3: CH3 enabled
ch4: CH4 enabled
ch5: CH5 enabled
unit: Interval unit
ch1_upload: CH1 upload
ch2_upload: CH2 upload
ch3_upload: CH3 upload
ch4_upload: CH4 upload
ch5_upload: CH5 upload
Wakeup
wakeup
Wake up the device from sleep/dormancy mode for a specified duration.
Watermark time zone
watermark_timezone
Time zone of the video watermark.
timezone: Time zone
Check terminal parameter
{"message_id":"8104"}
alarm_id: Alarm ID
storage_type: Storage type
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
quality: Quality
