Sinotrack ST-925
Sinotrack ST-925 is a container GPS tracker with a powerful battery and magnetic mount. The device features a shock alarm, movement alarm, geofence alarm, sleep mode, history route playback, 20000 mAh Li-Ion backup battery, IP65 water-resistant casing, and more.
Parameters (49)
Sinotrack ST-925
Flespi parses telemetry data from your Sinotrack ST-925 into a standardized JSON and lets you send commands to Sinotrack ST-925 via API.
    "device.type.id": "Sinotrack ST-925",
    "protocol.id": "sinotrack"
How to send commands to Sinotrack ST-925?
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Message ID 0x0704
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Message ID 0x0704
city.id
ID of device's home city"
Message ID 0x0704
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Binary packet $,
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
manufacturer.code
Device manufacturer code"
manufacturer.device.code
Message ID 0x0704
Message ID 0x0704
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Message ID 0x0704
province.id
ID of device's home province"
Message ID 0x0704
Message ID 0x0704
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8,
Message ID 0x0704
Command *V4
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Binary packet $,
Command *V1,
Command *V4,
Command *V5,
Command *V6,
Command *V8
Block Engine
block_engine
mode: Switch mode
cut_off: Cut Off
timings: Comma separated list of times
Set sending interval
interval
Set the sending interval
cycle_time: Interval
Send custom command to device. GPRS command: not waiting for response, Scheme: "*,,#". You have to specify payload only. SMS command: specify full SMS text with SMS password
Mileage query command S32
{"payload":"S32,000000,1"}
