Squarell REMOTE
The REMOTE is the one box solution that combines a vehicle data collection device with modem functionality.
Its compact design houses all you need to supply your customers with: Squarell vehicle data, Remote Tacho Download, vehicle diagnostics (Tell Tales), driver coaching (DAP) and Event Data Recorder (EDR).
The REMOTE communicates over the LTE Cat-M network and has 2G fallback. Thanks to its extensive communication protocols and expandable hardware and software, Squarell offers you a versatile all-in-one telematics solution.
Parameters (213)
Settings (18)
Squarell REMOTE
Flespi parses telemetry data from your Squarell REMOTE into a standardized JSON and lets you send commands to Squarell REMOTE via API.
    "device.type.id": "Squarell REMOTE",
    "protocol.id": "squarell"
How to send commands to Squarell REMOTE?
acceleration.threshold.exceeded.duration
Duration of accerelation exceeding the threshold
$FMS4 message
$FMS10 message
ain.event
AIN event
$FMS10 message
$FMS1 message
$FMS1 message
$FMS1 message
can.brake.lights.status
$FMS8 message
$FMS1 message
can.doors.lock.status
Doors locked, read from CAN
$FMS8 message
can.eco.mode.enabled.status
ECO mode enabled/disabled status
$FMSEV1 message
$FMS1 message
$FMS1 message
can.engine.running.status
Engine running status, read from CAN
$FMS8 message
$FMS1 message
$FMS1 message
can.ev.brake.regeneration.mileage
Total distance covered during brake regeneration
$FMSEV4 message
can.ev.brake.regeneration.time
Total time spent in brake regeneration
$FMSEV4 message
can.ev.total.charged.energy
Total energy charged to EV battery
$FMSEV4 message
can.ev.total.discharged.energy
Total discharged energy
$FMSEV4 message
can.ev.total.driving.discharged.energy
Total discharged energy driving
$FMSEV4 message
can.ev.total.idle.time
Total time vehicle was idle with speed=0
$FMSEV4 message
can.ev.total.ignition.on.time
Total time with ignition on
$FMSEV4 message
can.ev.total.ignition.time.park
Total time with ignition on while in park
$FMSEV4 message
can.ev.total.regenerated.charge.energy
Total regenerated charge
$FMSEV4 message
$FMS8 message
$FMS8 message
can.front.left.seatbelt.status
Front left seatbelt fastened status, read from CAN
$FMS8 message
$FMS8 message
can.front.right.seatbelt.status
Front right seatbelt fastened status, read from CAN
$FMS8 message
can.front.wipers.status
Front wipers status, read fron CAN
$FMS8 message
$FMS1 message,
$FMS3 message
$FMS4 message
$FMS1 message
$FMS8 message
$FMS8 message
can.ignition.switch.status
Ignition switch on/off status, read from CAN
$FMS8 message
$FMS1 message
$FMS8 message
can.main.lights.status
Main lights status, read from CAN
$FMS8 message
can.motor.rpm
$FMSEV1 message
can.motor.temperature
$FMSEV1 message
can.motor.torque.level
Electric motor torque level, read from CAN bus
$FMSEV1 message
can.movement.status
$FMS8 message
$FMS8 message
$FMS1 message
$FMS1 message
$FMS1 message
$FMS8 message
$FMS8 message
$FMS8 message
$FMS8 message
$FMS8 message
can.rear.wipers.status
Rear wipers status, read from CAN
$FMS8 message
$FMS8 message
$FMS8 message
can.seatbelt.indicator.status
$FMS8 message
$FMS1 message
$FMS4 message
can.total.brake.threshold.exceeded.applications
Total count of break pedal application exceeding the threshold, read from CAN
$FMS4 message
can.total.clutch.applications
Total count clutch pedal applications, read from CAN
$FMS4 message
$FMS4 message
$FMS4 message
$FMS4 message
$FMS8 message
$FMSEV1 message
can.vehicle.battery.charging.cable.connected.status
Vehicle battery charging cable connected/disconnected status, read from CAN
$FMSEV1 message
$FMSEV1 message
$FMSEV1 message
$FMSEV1 message
$FMSEV1 message
$FMSEV1 message
can.vehicle.battery.remaining.time
$FMSEV1 message
$FMSEV1 message
$FMS1 message,
$FMS3 message
$FMS1 message
dcf.firmware.version
DCF firmware version
$POWERON message
$POWERON message
device.profile
Device profile
$POWERON message
CONNECTION message
$POWERON message,
$SHUTDOWN message
engine.torque.threshold.exceeded.duration
Duration of engine torque exceeding the threshold
$FMS4 message
envelope.version
Envelope protocol version
Envelope header
$FMS10 message
$FMS10 message
$FMS4 message
$FMS4 message
fota.state
FOTA status
$FOTASTATUS message
gsm.network.name
CONNECTION message
CONNECTION message
idle.threshold.exceeded.duration
Duration of idle state exceeding the threshold
$FMS4 message
last.fota.timestamp
Last FOTA time
$FOTASTATUS message
Envelope header
$POWERON message
next.fota.timestamp
Next planned FOTA time
$FOTASTATUS message
Message header
Message header
Message header
Message header
Message header
Message header
Message header
power.off.reason
Power off reason
$SHUTDOWN message
$POWERON message
Message header
Envelope header
rpm.threshold.exceeded.duration
Duration of RPM exceeding the threshold
$FMS4 message
speed.threshold.exceeded.duration
Duration of speed exceeding the threshold
$FMS4 message
$FMS3 message
$FMS3 message
$FMS3 message
$FMS3 message
$FMS3 message
$FMS3 message
$FMS3 message
$FMS3 message
tacho.driving.direction
$FMS3 message
tacho.handling.info.status
$FMS3 message
$FMS3 message
tacho.performance
Tachograph performance
$FMS3 message
$FMS3 message
tacho.system.event.status
Tacho system event occurred
$FMS3 message
Message header
trailer.abs.active.count
The number of times ABS (anti-lock braking system) has been actived for trailer
$FMS12 message
trailer.cargo.weight
Cargo weight in trailer
$FMS12 message
trailer.couple.status
Trailer coupled/decoupled status
$FMS12 message
trailer.ebs.awl.status
State of the EBS (electronic braking system) amber warning light for trailer
$FMS12 message
trailer.ebs.rsl.status
State of the EBS (electronic braking system) red stop light for trailer
$FMS12 message
trailer.esc.active.count
The number of times ESC (electronic stability control system) has been actived for trailer
$FMS12 message
trailer.id
Trailer ID
$FMS12 message
trailer.total.axle.weight
Weight on the axles of trailer
$FMS12 message
trailer.vin
Trailer VIN
$FMS12 message
trailer.weight
Total weight of trailer
$FMS12 message
updater.firmware.version
Updater firmware version
$POWERON message
vehicle.interface.firmware.version
Vehicle interace firmware version
$POWERON message
$FMS2 message
$FMS2 message
ACK
ack
ACK Timeout
ack_timeout
Access Point Name
APN Password
apn_pass
APN Password
APN Username
apn_user
APN Username
Backend Server
Backend Server Host
Direct Message Transmit Interval
direct_transmit
Extended device info
extended_version
Readonly settings to check the extended device info
dcf_name: Name of the DCF
fw_version: Firmware version of the device
hw_version: Hardware version of the device
sw_version: Software version of the device
ddf_version: DDF version of the device
gds_version: GDS version of the device
product_code: Product code of the device
serial_number: Serial number of the device
product_profile: Product profile of the device
Heartbeat Interval
heartbeat
heartbeat: Enable
ICCID
iccid
iccid: GSM Sim ICCID
Port
port
Backend Server Port Number
Port diagnostic info
port_diag
If firmware detects no activity and DCF received no messages, SFD device may not be connected or is defected. If firmware detects activity and DCF receives no messages, DCF could not be programmed to receive messages from that specific SFD device. Please contact Support department.
can_1: CAN 1
can_2: CAN 2
j1708: J1708
k_line: K-Line
datacliq_can_180: DatacliQ CAN 180
datacliq_can_181: DatacliQ CAN 181
datacliq_can_190: DatacliQ CAN 190
datacliq_j1708_280: DatacliQ J1708 280
Relay
relay
Relay Control
cut_off: Cut Off Relay
Request CAN Bus Kbaud value
rtdcan
Settings to check/control the tachograph Kbaud value
mode: Kbaud value
Checking the tachograph configuration (TachoK)
tachok_info
counter: Counter. Tacho attempts to identify the tacho type
tacho_type: Tacho type status
k_line_active: K-Line active. Device is able to see if there is data on the range wire
not_important: Not important
messages_received: Messages are received & processed into the device
Setup tachograph configuration (SetTachoK)
tachok_setup
Settings to setup the tachograph configuration
reset_command: Reset command
Transmit Interval
transmit
Get IMEI
{"payload":"$STATUS,8"}
Get location
{"payload":"$STATUS,16"}
Turn the RELAY ON
{"payload":"$CONTROL,4,1"}
Turn the RELAY OFF
{"payload":"$CONTROL,4,0"}
Request tachograph file
request_tachograph_file
More devices from Squarell Technology
No results found.
