StarLink Tracker
StarLink Tracker is a modular GPS tracking device supporting 2G Quad-band GSM, allowing extensive diagnostics, fuel theft notifications, and featuring embedded antennas and cellular jamming detection. Possible configurations may include Wi-Fi, Bluetooth, CAN, voice communication, driver ID, and more.
Parameters (151)
Settings (3)
Commands (5)
StarLink Tracker
Flespi parses telemetry data from your StarLink Tracker into a standardized JSON and lets you send commands to StarLink Tracker via API.
    "device.type.id": "StarLink Tracker",
    "protocol.id": "erm"
How to send commands to StarLink Tracker?
accident.direction
Direction of accident
Message Type 6 with Event code 41
accident.direction.description
Description of accident direction
accident.event
Accident event detected
Message Type 6 with Event code 12,
Message Type 6 with Event code 13,
Message Type 7,
Parameter #V3#,
Parameter #V4#
ain.voltage.low.status
Analog input's voltage is below the threshold
Message Type 6 with Event code 36
Parameter #BATH#
Parameter #BATC#
Message Type 6 with Event code 11
Parameter #V2#,
Parameter #VBAT#
Message Type 64
call.duration
Call duration
Message Type 6 with Event code 39
Message Type 6 with Event code 38
call.return.code
Call return code
Message Type 6 with Event code 37
call.type
Call type
call.type.enum
Call type number
can.param
CAN parameter value
Parameter #CV1#,
Parameter #CV2#,
Parameter #CV3#,
Parameter #CV4#
current.satellites.visible
Current number of visible satellites
Parameter #SATN#
destination.number
Selected destination number
Message Type 6 with Event code 34,
Parameter #DEST#
Message Type 29
Message Type 29
Parameter #TVI#
Message Type 16,
Message Type 6 with Event code 14,
Message Type 6 with Event code 15,
Parameter #IN1#,
Parameter #IN2#,
Parameter #IN3#,
Parameter #IN4#,
Parameter #IN5#,
Parameter #IN7#,
Parameter #IN8#,
Parameter #INC#,
Parameter #IND#,
Parameter #INE#,
Parameter #INF#,
Parameter #ING#,
Parameter #INI#,
Parameter #INJ#,
Parameter #INK#,
Parameter #INL#
Message Type 20
Message Type 12,
Parameter #OUT1#,
Parameter #OUT2#,
Parameter #OUT3#,
Parameter #OUT4#,
Parameter #OUT5#,
Parameter #OUT6#,
Parameter #OUT7#,
Parameter #OUT8#,
Parameter #OUTA#,
Parameter #OUTB#,
Parameter #OUTC#,
Parameter #OUTD#
Parameter #DID#
econnect.peer
eConnect peer device data (StarLink unit-to-unit proximity detection)
Message Type 6 with Event code 5
Message Type 20,
Message Type 6 with Event code 1,
Message Type 6 with Event code 4,
Message Type 6 with Event code 5,
Parameter #IGN#
Parameter #TDUR#
Parameter #RPM#
engine.status
Engine status
Message Type 6 with Event code 24,
Message Type 6 with Event code 25,
Parameter #ENG#
error.info
Additional information about error sent by device
error.level
Protocol-specific error level
error.level.description
Protocol-specific error level description
error.type.description
Parameter #EDSC#
Parameter #EID#
external.device.firmware.version
External device firmware version
Message Type 6 with Event code 73,
Message Type 6 with Event code 74
external.device.id
External device ID
Message Type 6 with Event code 33,
Message Type 6 with Event code 40,
external.device.value
External device value
Parameter #EDV1#,
Parameter #EDV2#,
Parameter #EDV3#,
Parameter #EDV4#,
Parameter #EDX1#,
Parameter #EDX2#,
Parameter #EDX3#,
Parameter #EDX4#
Message Type 6 with Event code 10,
Message Type 6 with Event code 9
Parameter #V1#,
Parameter #VIN#
Message Type 35
Message Type 35
Parameter #CFL#,
Parameter #CFL2#
Message Type 6 with Event code 7,
Message Type 6 with Event code 8
Message Type 6 with Event code 90,
Message Type 6 with Event code 91
gnss.signal.level
Current average signal level of visible satellites
Parameter #GSSN#
gsm.arfcn
Parameter #CCN#
Parameter #CID#
Parameter #JAM#
Message Type 6 with Event code 42,
Message Type 6 with Event code 43
Parameter #LAC#
Parameter #NC#
Parameter #NC#
Parameter #NM#
gsm.network.name
Message Type 6 with Event code 23
Message Type 6 with Event code 23,
Parameter #NM#
Parameter #NM#
Parameter #NT#
Parameter #NC#
Parameter #CSS#
Message Type 6 with Event code 94,
Message Type 6 with Event code 95
Parameter #CTA#
hood.open.status
Hood open status
Message Type 20
Message Type 6 with Event code 16,
Message Type 6 with Event code 46,
Message Type 6 with Event code 47,
Parameter #DAL#
Message Type 6 with Event code 22,
Message Type 6 with Event code 79
Parameter #IDL#
immobilizer.data
Immobilizer rule associated data
Message Type 6 with Event code 20,
Message Type 6 with Event code 21,
Message Type 6 with Event code 68,
Message Type 6 with Event code 93
immobilizer.override.mode
Immobilizer override mode status
Message Type 6 with Event code 77
immobilizer.rule
Immobilizer rule number
Message Type 6 with Event code 19,
Message Type 6 with Event code 35,
Message Type 6 with Event code 93,
Parameter #IARM#
immobilizer.trigger.input
Input switches bitmask, that triggered immobilizer violation event
lca.alarm.armed.status
Armed state
Message Type 20
lca.alarm.connection.status
Communication state
Message Type 20
lca.alarm.serial.number
Alarm serial number
Message Type 20
lca.alarm.siren.status
Sirene activate state
Message Type 20
lca.alarm.timestamp
Lca alarm timestamp
Message Type 20
lca.alarm.version
Alarm version
Message Type 20
location.filter.reason
Location filter reason
Parameter #LOCF#
location.source
Location source: 0 - location is invalid, 1 - GNSS location, 2 - Cellular location, 3 - Static location
Parameter #LOCS#
maneuver.duration
Maneuver duration
maneuver.total.severity.enum
maneuver.type
Maneuver type
maneuver.x.acceleration.max
maneuver.y.acceleration.max
maneuver.z.acceleration.max
max.position.speed
Maximum speed on segment
message.seqnum
motorcycle.accident.event
Motorcycle accident event
Message Type 6 with Event code 32
motorcycle.alarm
Motorcycle alarm event
Message Type 6 with Event code 27
motorcycle.alarm.reason.enum
Motorcycle alarm event reason: 1 - ignition switch, 2 - tilt sensor, 3 - shck sensor, 4 - port E
motorcycle.alarm.status
Motorcycle alarm status: true - armed, false - disarmed
Message Type 6 with Event code 28,
Message Type 6 with Event code 29
motorcycle.fall.angle
Motorcycle fall angle
Message Type 6 with Event code 31,
motorcycle.valet.mode.event
Motorcycle enters valet mode event
Message Type 6 with Event code 30
Message Type 6 with Event code 44,
Message Type 6 with Event code 45,
Message Type 6 with Event code 58,
Message Type 6 with Event code 59,
Parameter #DRV#
next.message
Estimated time until the next transmission
Parameter #NXT#
Parameter #LOCA#
Parameter #ALT#,
Parameter #ALTD#
Parameter #HEAD#
position.fix.type
Parameter #FIX#
position.gnss.signal.level
Average GNSS satellite signal level at the last GPS fix
Parameter #GSS#
Parameter #HDOP#
Parameter #LAT#,
Parameter #LTDD#
Parameter #LGDD#,
Parameter #LONG#
Parameter #PDOP#
Parameter #SATU#
position.satellites.visible
Parameter #SAT#
Parameter #SPD#,
Parameter #SPDK#
Parameter #PDI#,
Parameter #PDT#
Parameter #VDOP#
Message Type 1
Message Type 6 with Event code 18
Parameter #TH1#,
Parameter #TH2#,
Parameter #TH3#,
Parameter #TH4#
Parameter #TI1#,
Parameter #TI2#,
Parameter #TI3#,
Parameter #TI4#
sensor.state
Sensor state code: 0 - sensor error, 1 - temperature is valid, 2 - temperature is below valid range, 3 - temperature is above valid range
Parameter #TS1#,
Parameter #TS2#,
Parameter #TS3#,
Parameter #TS4#
Message Type 6 with Event code 56,
Parameter #TV1#,
Parameter #TV2#,
Parameter #TV3#,
Parameter #TV4#
Message Type 1,
Parameter #VER#
starter.duration
Time used to run engine by starter
Parameter #STRT#
tacho.overtime.event
Tacho overtime event
Message Type 6 with Event code 80
tacho.overtime.event.enum
Tacho overtime event type
tacho.overtime.event.state
Tacho overtime event type name
Message Type 7,
Parameter #EDI#,
Parameter #EDT#
total.idle.time
Message Type 6 with Event code 26
transmition.channel
Transmition channel
Parameter #CU#
Parameter #DUR#
Parameter #ODO#,
Parameter #ODOD#
Parameter #IGNL#
Configure primarybackend server information
protocol: Protocol
Dynamic parameters
dynamic_parameters
Dynamic parameters format for the Event report message
format: Format
Network Setup
Configure the GPRS/UMTS/LTE network parameters
command: Command number
Request immobilizer rule
{"command":23,"payload":"1"}
Request geo-zone configuration
{"command":10,"payload":"02"}
Request location (with 10 sec timeout to wait GNSS fix)
{"command":5,"payload":"10"}
Get param
Get configuration param value
Output off
output_off
Output off
outnum: Number/id of output
Output on
output_on
Output on
Set param
Set configuration param value
