Sunlab (Suntech) ST300A
Suntech ST300A is an advanced high-end GPS tracker supporting communication over TCP and UDP. The device features driving pattern analysis, 3-axis accelerometer, 1-Wire to connect up to 3 temperature sensors, backup battery, RS232 inputs/outputs, jamming detection, geo-fencing, FOTA, and more.
Parameters (318)
Settings (8)
Flespi parses telemetry data from your Sunlab (Suntech) ST300A into a standardized JSON and lets you send commands to Sunlab (Suntech) ST300A via API.
    "device.type.id": "Sunlab (Suntech) ST300A",
How to send commands to Sunlab (Suntech) ST300A?
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Reboot device
Report Parameters
reporting
Report generation parameters
status
