You can obtain telematics data from any Suntech device in 6 easy steps:
Set up the Suntech channel in your flespi.io interface.
Point a Sunlab (Suntech) device to your flespi account using the device configurator from Suntech or by sending an SMS command to the device.
Access Suntech device data via API.
2. Set up the Suntech channel on flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “suntech” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Suntech device to your flespi channel
You can do it with Suntech’s SyncTrak configurator tool (available by request from Suntech tech support) or by sending an SMS command to the device. Detailed instructions can be found on the Suntech Support website.
Suntech tech contacts vary based on the region where the customer is located:
- USA & EMEA: SunTech US Support
- Latin America: SunTech Soporte LATAM
While in the Channel dialogue box, click on the Logs & Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Suntech device data via API
"result": [
"backup.battery.voltage": 4.1,
"channel.id": 11128,
"device.id": 1735432,
"device.model": "st940",
"device.name": "Penguin",
"device.type.id": 414,
"din": 0,
"din.1": false,
"din.2": false,
"din.3": false,
"dout": 0,
"dout.1": false,
"dout.2": false,
"engine.ignition.status": true,
"engine.motorhours": 297.916667,
"event.code": "ALT",
"event.enum": 10,
"external.powersource.voltage": 12.61,
"gnss.vehicle.mileage": 3519.185,
"gsm.cellid": 0,
"gsm.lac": 0,
"gsm.mcc": 0,
"gsm.mnc": 0,
"gsm.signal.dbm": -110,
"ident": "107764423",
"message.buffered.status": true,
"peer": "201.166.177.179:22567",
"position.direction": 0,
"position.latitude": 19.372353,
"position.longitude": -98.979707,
"position.satellites": 3,
"position.speed": 0.163,
"position.valid": true,
"protocol.id": 125,
"server.timestamp": 1702668559.292488,
"software.version": "581",
"timestamp": 1702668516
}6. Create a flespi device
What's next?
