Sunlab (Suntech) ST310UC2
Suntech ST310UC2 is a compact, low cost GPS tracker with internal GPS and GPRS antennas. The device features jamming detection, 3-axis accelerometer, 2 digital inputs and 1 configurable digital output, IP67 water-resistant casing, and more.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST310UC2 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST310UC2 via API.
    "device.type.id": "Sunlab (Suntech) ST310UC2",
How to send commands to Sunlab (Suntech) ST310UC2?
ALT Report Header 24,
Standard parameter names used: *id* - beacon identification string. Usually it is beacon's UUID or MAC-address *local_name* - Beacons's Local Name *rssi* - BLE signal level. Units = dBm *battery.voltage* - Beacon's battery voltage. Units = volts *battery.voltage.volts* - Beacon's battery voltage in volts (transition field, will be removed after 2026-05-19) *battery.level* - Beacon's battery level. Units = percentage *temperature* - Beacon's temperature. Units = celsius
