Trak-IoT TC10
TC10 is a wired 4G LTE vehicle tracker for fleets, supporting GPS/GLONASS/Beidou with <10 m accuracy. It offers real-time tracking, driving behavior analysis, tamper alarm, ACC ignition detection, SOS, and remote immobilizer. Interfaces include 3 digital inputs, 1 digital output, analog input, 1‑Wire, and optional RS‑232/RS‑485/TTL for sensors and peripherals. Built-in mic, speaker, and TTS enable voice prompts; Bluetooth module supported. Features IP65 casing, internal antennas, 9–36V power with 145 mAh backup battery, micro‑SIM, and 5V peripheral power.
Parameters (73)
Trak-IoT TC10
Flespi parses telemetry data from your Trak-IoT TC10 into a standardized JSON and lets you send commands to Trak-IoT TC10 via API.
    "device.type.id": "Trak-IoT TC10",
    "protocol.id": "trak-iot"
Tag 0x2003 of Frame Type 0x0101,
Tag 0x2003 of Frame Type 0x0102,
Tag 0x2003 of Frame Type 0x0103,
Tag 0x2003 of Frame Type 0x0104
Tag 0x2415 of Frame Type 0x0101,
Tag 0x2415 of Frame Type 0x0102
Tag 0x240F of Frame Type 0x0101,
Tag 0x240F of Frame Type 0x0102,
Tag 0x240F of Frame Type 0x0103,
Tag 0x240F of Frame Type 0x0104,
Tag 0x240D of Frame Type 0x0101,
Tag 0x240D of Frame Type 0x0102,
Tag 0x240D of Frame Type 0x0103,
Tag 0x240D of Frame Type 0x0104,
collision.grade.enum
Collision severity grade
Tag 0x2821 of Frame Type 0x0101,
Tag 0x2821 of Frame Type 0x0102,
Tag 0x2821 of Frame Type 0x0103,
Tag 0x2821 of Frame Type 0x0104
collision.sensor.type.enum
Collision detection sensor type
Tag 0x2822 of Frame Type 0x0101,
Tag 0x2822 of Frame Type 0x0102,
Tag 0x2822 of Frame Type 0x0103,
Tag 0x2822 of Frame Type 0x0104
collision.speed
Collision speed
cornering.reason.enum
Cornering event trigger reason
Tag 0x2110 of Frame Type 0x0101,
Tag 0x2110 of Frame Type 0x0102,
Tag 0x2110 of Frame Type 0x0103,
Tag 0x2110 of Frame Type 0x0104
Tag 0x2406 of Frame Type 0x0101,
Tag 0x2406 of Frame Type 0x0102,
Tag 0x2406 of Frame Type 0x0103,
Tag 0x2406 of Frame Type 0x0104
Tag 0x2400 of Frame Type 0x0101,
Tag 0x2400 of Frame Type 0x0102,
Tag 0x2400 of Frame Type 0x0103,
Tag 0x2400 of Frame Type 0x0104,
Tag 0x2970 of Frame Type 0x0101,
Tag 0x2970 of Frame Type 0x0102,
Tag 0x2970 of Frame Type 0x0103,
Tag 0x2970 of Frame Type 0x0104
Tag 0x2047 of Frame Type 0x0101,
Tag 0x2047 of Frame Type 0x0102,
Tag 0x2047 of Frame Type 0x0103,
Tag 0x2047 of Frame Type 0x0104
Tag 0x2046 of Frame Type 0x0101,
Tag 0x2046 of Frame Type 0x0102,
Tag 0x2046 of Frame Type 0x0103,
Tag 0x2046 of Frame Type 0x0104
Tag 0x2032 of Frame Type 0x0101,
Tag 0x2032 of Frame Type 0x0102,
Tag 0x2032 of Frame Type 0x0103,
Tag 0x2032 of Frame Type 0x0104,
Tag 0x2310 of Frame Type 0x0101,
Tag 0x2310 of Frame Type 0x0102,
Tag 0x2310 of Frame Type 0x0103,
Tag 0x2310 of Frame Type 0x0104,
Tag 0x2333 of Frame Type 0x0101,
Tag 0x2333 of Frame Type 0x0102,
Tag 0x2333 of Frame Type 0x0103,
Tag 0x2333 of Frame Type 0x0104
Frame serial number
Tag 0x2415 of Frame Type 0x0102,
Tag 0x2415 of Frame Type 0x0103,
Tag 0x2415 of Frame Type 0x0104
Frame Type 0x0103,
Frame Type 0x0104,
Tag 0x2160 of Frame Type 0x0101,
Tag 0x2160 of Frame Type 0x0102,
Tag 0x2184 of Frame Type 0x0101,
Tag 0x2184 of Frame Type 0x0102
geofence.in.alarm
Geofence in alarm event
Frame Type 0x0103,
Frame Type 0x0104,
geofence.out.alarm
Geofence out alarm event
Frame Type 0x0103,
Frame Type 0x0104,
Tag 0x2130 of Frame Type 0x0101,
Tag 0x2130 of Frame Type 0x0102,
Tag 0x2130 of Frame Type 0x0103,
Tag 0x2130 of Frame Type 0x0104
Frame Type 0x0103,
Frame Type 0x0104,
Tag 0x2460 of Frame Type 0x0101,
Tag 0x2460 of Frame Type 0x0102
Tag 0x2750 of Frame Type 0x0101,
Tag 0x2750 of Frame Type 0x0102,
Tag 0x2750 of Frame Type 0x0103,
Tag 0x2750 of Frame Type 0x0104
Tag 0x26F0 of Frame Type 0x0101,
Tag 0x26F0 of Frame Type 0x0102,
Tag 0x26F0 of Frame Type 0x0103,
Tag 0x26F0 of Frame Type 0x0104
ignition.detection.mode.enum
Ignition detection mode
motion.moving.to.stationary.duration
Duration from moving to stationary state transition (seconds)
Tag 0x2005 of Frame Type 0x0101,
Tag 0x2005 of Frame Type 0x0102,
Tag 0x2005 of Frame Type 0x0103,
Tag 0x2005 of Frame Type 0x0104
motion.since.last.moving.duration
Time elapsed since the device was last in moving state (seconds)
Tag 0x2004 of Frame Type 0x0101,
Tag 0x2004 of Frame Type 0x0102,
Tag 0x2004 of Frame Type 0x0103,
Tag 0x2004 of Frame Type 0x0104
motion.since.last.stationary.duration
Time elapsed since the device was last in stationary state (seconds)
motion.stationary.to.moving.duration
Duration from stationary to moving state transition (seconds)
Tag 0x2333 of Frame Type 0x0104,
Tag 0x2095 of Frame Type 0x0101,
Tag 0x2095 of Frame Type 0x0102,
Tag 0x2095 of Frame Type 0x0103,
Tag 0x2095 of Frame Type 0x0104,
Tag 0x2096 of Frame Type 0x0101,
Tag 0x2096 of Frame Type 0x0102,
Tag 0x2096 of Frame Type 0x0103,
Tag 0x2096 of Frame Type 0x0104
position.fix.enum
Tag 0x2210 of Frame Type 0x0101,
Tag 0x2210 of Frame Type 0x0102,
Tag 0x2210 of Frame Type 0x0103,
Tag 0x2210 of Frame Type 0x0104
Tag 0x2094 of Frame Type 0x0101,
Tag 0x2094 of Frame Type 0x0102,
Tag 0x2094 of Frame Type 0x0103,
Tag 0x2094 of Frame Type 0x0104,
position.source
Tag 0x2050 of Frame Type 0x0101,
Tag 0x2050 of Frame Type 0x0102,
Tag 0x2050 of Frame Type 0x0103,
Tag 0x2050 of Frame Type 0x0104
Tag 0x2096 of Frame Type 0x0104,
sos.location.mode.enum
SOS location reporting mode
Tag 0x2252 of Frame Type 0x0101,
Tag 0x2252 of Frame Type 0x0102,
Tag 0x2252 of Frame Type 0x0103,
Tag 0x2252 of Frame Type 0x0104
sos.trigger.reason.enum
SOS trigger reason
Tag 0x2250 of Frame Type 0x0101,
Tag 0x2250 of Frame Type 0x0102,
Tag 0x2250 of Frame Type 0x0103,
Tag 0x2250 of Frame Type 0x0104
Tag 0x2130 of Frame Type 0x0104,
Tag 0x23A3 of Frame Type 0x0101,
Tag 0x23A3 of Frame Type 0x0102,
Tag 0x23A3 of Frame Type 0x0103,
Tag 0x23A3 of Frame Type 0x0104
Tag 0x240C of Frame Type 0x0101,
Tag 0x240C of Frame Type 0x0102,
Tag 0x240C of Frame Type 0x0103,
Tag 0x240C of Frame Type 0x0104,
