Xirgo FMS500 XtCAN
FMS500 XtCAN is a versatile vehicle tracking and telematics device with dual CAN-bus connections. It supports FMS CAN protocol, monitors temperature and fuel levels, and offers geofencing, driver identification, and remote output control. The device includes an accelerometer, operates on a wide voltage range, and has internal memory for extensive data logging. It is equipped with GSM jamming detection, internal GNSS antenna, and is designed to be installed securely within the vehicle cabin.
Parameters (120)
Settings (1)
Xirgo FMS500 XtCAN
Flespi parses telemetry data from your Xirgo FMS500 XtCAN into a standardized JSON and lets you send commands to Xirgo FMS500 XtCAN via API.
    "device.type.id": "Xirgo FMS500 XtCAN",
    "protocol.id": "bce"
How to send commands to Xirgo FMS500 XtCAN?
accident.event
Accident event detected
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
arm.status
Data Type 7
axle.weight
Axle weigth
Data Type 7
Data Type 7
Data Type 7,
Mask2: acc_pedal
Data Type 7
Data Type 7,
Mask2: j1939_air_temp
can.calculated.instant.fuel.consumption
Instant fuel consumption calculated from non standard can bus messages
Data Type 7,
Mask4: fuel_con_ins
Data Type 7
Data Type 12
can.dtc.type
Error types by status (confirmed, pending, permanent, history, mil) read from CAN *confirmed* - Confirmed faults, Check Engine is on *pending* - Pending faults, may disappear *permanent* - Stored faults, only cleared after a successful test *history* - Historical faults that have cleared but remain in memory *mil* - Faults that trigger the Check Engine light (MIL - Malfunction Indicator Lamp)
Data Type 12 with Sub Data Type 4,
Data Type 12 with Sub Data Type 5,
Data Type 7,
Mask2: engine_temp
Data Type 7,
Mask2: j1939_fuel_rate
Data Type 7
Data Type 7,
Mask2: j1939_eng_load
Data Type 7,
Mask2: can_engine_hrs
Data Type 7,
Mask2: can_taho
Data Type 7
can.fms.tco1.bitmask
CAN FMS TCO1 tachograph data bitmask
Data Type 7
Data Type 7
Data Type 7
Data Type 7,
Mask2: total_fuel
Data Type 7
Data Type 7,
Mask2: can_fls,
Mask2: j1939_fuel_lvl2
Data Type 7
can.j1587.dtc.lci
can.j1587.dtc.oc
can.j1587.dtc.status
can.j1587.dtc.type
can.j1939.dm1.dtc.awl
can.j1939.dm1.dtc.awl.flash
can.j1939.dm1.dtc.mil
can.j1939.dm1.dtc.mil.flash
can.j1939.dm1.dtc.pl
can.j1939.dm1.dtc.pl.flash
can.j1939.dm1.dtc.rsl
can.j1939.dm1.dtc.rsl.flash
can.j1939.dm1.dtc.sa
can.j1979.s10.dtc.sa
can.j1979.s3.dtc.sa
can.j1979.s7.dtc.sa
Data Type 7,
Mask2: j1939_srv_dist
Data Type 7
Data Type 7
Data Type 7
Data Type 7,
Mask2: can_mileage
Data Type 7,
Mask2: wheel_speed
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
engine.generator.status
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 6
event.function
Event function
Data Type 6
Data Type 7
filtered.ain
Filtered analog input value
Data Type 7
frequency.counter.din
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 9
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 6
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
tilt.status
Data Type 7
Data Type 7
Data Type 7
total.trailer.weight
Total trailer weight
Data Type 7
trailer.id
Trailer ID
Data Type 7
trailer.state.bitmask
Trailer status
Data Type 7
ussd.data
USSD data
Data Type 11
Data Type 1,
Data Type 7
wiegand.code
Wiegand26 RFID code
Data Type 7
Activate output 1
type: Pulse Type
