Zimo S3
Zimo S3 is a sharing electric scooter made from aircraft-grade aluminum alloy. The device features a 522Wh battery sufficient to ride up to 45 km, powerful waterproof motor, 10-inch non-inflatable tires, 1.5W high brightness dual lighting system, front & rear drum brake and rear EABS, double LED tail light, invisible wire design, and more.
Parameters (59)
Settings (10)
Zimo S3
Flespi parses telemetry data from your Zimo S3 into a standardized JSON and lets you send commands to Zimo S3 via API.
    "device.type.id": "Zimo S3",
    "protocol.id": "zimo"
How to send commands to Zimo S3?
battery.charging.cycles
battery.full
Battery fully charged
battery.id.serial
Battery serial number
device.hardware.state.flag
Device hardware state flag
ecu.hardware.version.enum
Electronic control unit hardware version
ecu.software.version.enum
Electronic control unit software version
Hardware version enum
position.fix.type
position.speed.limit
Speed limit
product.id
Product ID
riding.kickstand.alarm
Scoooter kickstand status 1= lifted, 0 = unlifted
scooter.protection.unauthorized.movement
Scooter unauthorized movement check
Software version enum
total.idle.time
total.trip.mileage
Total trip mileage
wheel.speed
RPM from motor hall sensor, wheel circumference
Buzzer and Light at the same time On/Off
alarm
state: Off/On
Audio play
audio
state: Off/On
Battery lock
battery_lock
lock: Lock/Unlock
Buzzer On/Off
buzzer
state: Off/On
Idle On/Off
idle
idle: Off/On
Lights On/Off
lights
state: Off/On
Turn on Ebrake to lock motor.
lock
lock: Lock/Unlock
Activate the scooter
power_on_id
state: Off/On
Speed limit
speedlim
speedlim: Speed limit
Audio Volume
volume
audiovol: Audio Volume
autoplay: Auto Play
command: Command
argument: Argument
