Bitrek-cicada protocol
Protocol used by Cicada series of GPS tracking devices manufactured by Bitrek headquartered in Ukraine.
flespi parses the Bitrek-cicada protocol messages into a JSON object with the fields listed below in the Parameters tab.
To connect your tracker using the Bitrek Cicada protocol, you need to have a bitrek-cicada channel created first.
device.wakeup.source
Device wakeup source
gnss.fix.duration
gps.error.enum
GPS position obtaining error code
gsm.network.name
gsm.stations.updated
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) station info after TA parameter update
last.sleep.reason
The last reason for device sleep
last.sleep.timeout
Last device sleep timeout
modem.power.on.count
The number of times the modem has been powered on
position.fix.type
reboot.reason.bitmask
Device reboot reason bitmask
scan.duration
Scan duration
scan.previous.duration
Previous scan duration
scan.start.count
Number of scans
scan.start.success.count
Number of successful scans
total.device.uptime
Total device working time
Send custom command in response to the device request
Change parameter XXXX value to YYYY
{"payload":"setparam XXXX YYYY"}
