BI 310 CICADA
BI 310 CICADA is a beacon used for tracking and control of moving objects via GPS or LBS. The device features small dimensions, a non-rechargeable 3200mAh battery (allows sending approx. 1400 positions), FOTA, IP64 ingress protection, and more.
Parameters (48)
Settings (4)
BI 310 CICADA
Flespi parses telemetry data from your BI 310 CICADA into a standardized JSON and lets you send commands to BI 310 CICADA via API.
    "device.type.id": "BI 310 CICADA",
    "protocol.id": "bitrek-cicada"
How to send commands to BI 310 CICADA?
device.wakeup.source
Device wakeup source
gnss.fix.duration
gps.error.enum
GPS position obtaining error code
gsm.network.name
gsm.stations.updated
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) station info after TA parameter update
last.sleep.reason
The last reason for device sleep
last.sleep.timeout
Last device sleep timeout
modem.power.on.count
The number of times the modem has been powered on
position.fix.type
reboot.reason.bitmask
Device reboot reason bitmask
scan.duration
Scan duration
scan.previous.duration
Previous scan duration
scan.start.count
Number of scans
scan.start.success.count
Number of successful scans
total.device.uptime
Total device working time
GPRS APN
gprs_apn
GPRS APN Setup
gprs_login: GPRS Login
gprs_password: GPRS Password
Pursuit Mode
pursuit_mode
Pursuit mode configuration
Server
Server Setup
Sleep Timeouts
sleep_time
Main sleep timeouts
fail1: First Attempt Timeout
fail2: Second Attempt Timeout
timeout_success: Success Timeout
Send custom command in response to the device request
Change parameter XXXX value to YYYY
{"payload":"setparam XXXX YYYY"}
