To connect your tracker using the Morey Slap-n-Track MQTT protocol, you need to have a morey-slap-n-track channel created first.
Then create a device instance for your tracker and use a 15-character IMEI (usually specified on the tracker casing) in the ident field.
It is possible to configure Morey Slap-n-Track devices OTA using the flespi web-based configurator tool. To connect Morey Slap-n-Track to Wialon or another platform via flespi please read this article.
Once you create a Morey Slap-n-Track MQTT protocol, you can configure it as needed:
