Mystic-parrot protocol
Protocol used by GPS tracking devices manufactured by Mystic Parrot headquartered in the UK.
flespi parses the Mystic-parrot protocol messages into a JSON object with the fields listed below in the Parameters tab.
To connect your tracker using the Mystic Parrot protocol, you need to have a mystic-parrot channel created first.
It is possible to configure Mystic Parrot devices OTA using the flespi web-based configurator tool. To connect Mystic Parrot to Wialon or another platform via flespi please read this article.
communication.interupted
Communication interupted
device.id.number.error
device.run.time
Device run time
domain.name.error
downloading.agps
Downloading AGPS data
function.code
Function code, protocol-specific value
function.keyword
gps.module.error
GPS module error flag
g.sensor.error
G-sensor error
high.temperature.alarm
High temperature alarm
improper.installation
ip.error
low.temperature.alarm
Low temperature alarm
message.reason
Message reason. 1 - Power off restart(Power on reset); 2 - wake up from standby; 3 - Software reset; 0 - Other reset
module.error.no.response
Module error, No response
network.register.failure
Network register failure
no.signal
No signal
pdp.activation.context.failed
PDP activation context failed
removal.status
Removal satus
rtc.error
RTC Error
sim.card.error
spi.flash.fault
SpiFlash fault
temperature.sensor.connected
Temperature sensor connected status
track.mode
Track mode
wifi.module.error
WIFI module error
Custom OTA text command
Send custom OTA text command to device
text: Text payload
Query timezone
{"text":"UTC"}
Restart the device
{"text":"RESET"}
Query Server IP information
{"text":"IP"}
