Mystic Parrot M-NT08E
Mystic Parrot M-NT08E is a non-rechargeable Cat-M1/NB-IoT long standby asset GPS tracker. The device features built-in G-sensor. temperature monitor, 20,000 mAh battery that can be last for 10 years based on reports one GPS position every day, tamper proof alarm, multiple position mode: GPS, Wi-Fi, AGPS, LBS, jamming detection, motion alarm, IP67 waterproof casing, regular mode, clock mode, track mode, magnetic mount, and more.
Parameters (60)
Settings (9)
Flespi parses telemetry data from your Mystic Parrot M-NT08E into a standardized JSON and lets you send commands to Mystic Parrot M-NT08E via API.
    "device.type.id": "Mystic Parrot M-NT08E",
    "protocol.id": "mystic-parrot"
How to send commands to Mystic Parrot M-NT08E?
communication.interupted
Communication interupted
device.id.number.error
device.run.time
Device run time
domain.name.error
downloading.agps
Downloading AGPS data
function.code
Function code, protocol-specific value
function.keyword
gps.module.error
GPS module error flag
g.sensor.error
G-sensor error
high.temperature.alarm
High temperature alarm
improper.installation
ip.error
low.temperature.alarm
Low temperature alarm
message.reason
Message reason. 1 - Power off restart(Power on reset); 2 - wake up from standby; 3 - Software reset; 0 - Other reset
module.error.no.response
Module error, No response
network.register.failure
Network register failure
no.signal
No signal
pdp.activation.context.failed
PDP activation context failed
removal.status
Removal satus
rtc.error
RTC Error
sim.card.error
spi.flash.fault
SpiFlash fault
temperature.sensor.connected
Temperature sensor connected status
track.mode
Track mode
wifi.module.error
WIFI module error
password: APN password
username: APN username
ICCID of SIM card
iccid
iccid: ICCID
Positioning mode
positioning_mode
mode: Positioning mode
lbs_enable: LBS Enable
Device remaining usage time
remaining_usage_time
usage_time: Remaining usage time
Server IP
server_ip
host: Server Host
port: Server Port
type: Transport Type
Upload interval in sleep mode
sleep_mode_upload_interval
interval: Upload interval
The device standby time based on one day one ping
standby_time
standby_time: Standby time
Time zone
time_zone
zone: Time zone
Upload mode
upload_mode
upload: Upload mode
Custom OTA text command
Send custom OTA text command to device
text: Text payload
Query timezone
{"text":"UTC"}
Restart the device
{"text":"RESET"}
Query Server IP information
{"text":"IP"}
