Xirgo FM-500 Light+
Xirgo FM-500 Light+ is a device with GPS/GLONASS and GSM connectivity, designed for object tracking. It is able to acquire information on object location, speed, direction, etc. and transfer the data via GSM network. Digital and analog inputs of the device may be used to connect different external sensors/devices. Outputs of the device may be used to control external equipment remotely. Flexible configuration allows users/dealers to adjust the device to meet their specific requirements. It has 1-Wire (iButton), RS-232 and EIA-485 interfaces.
Parameters (116)
Settings (6)
Xirgo FM-500 Light+
Flespi parses telemetry data from your Xirgo FM-500 Light+ into a standardized JSON and lets you send commands to Xirgo FM-500 Light+ via API.
    "device.type.id": "Xirgo FM-500 Light+",
    "protocol.id": "bce"
How to send commands to Xirgo FM-500 Light+?
accident.event
Accident event detected
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
arm.status
Data Type 7
axle.weight
Axle weigth
Data Type 7
Data Type 7
Data Type 7,
Mask2: acc_pedal
Data Type 7
Data Type 7,
Mask2: j1939_air_temp
can.calculated.instant.fuel.consumption
Instant fuel consumption calculated from non standard can bus messages
Data Type 7,
Mask4: fuel_con_ins
Data Type 7
Data Type 12
can.dtc.type
Error types by status (confirmed, pending, permanent, history, mil) read from CAN *confirmed* - Confirmed faults, Check Engine is on *pending* - Pending faults, may disappear *permanent* - Stored faults, only cleared after a successful test *history* - Historical faults that have cleared but remain in memory *mil* - Faults that trigger the Check Engine light (MIL - Malfunction Indicator Lamp)
Data Type 12 with Sub Data Type 4,
Data Type 12 with Sub Data Type 5,
Data Type 7,
Mask2: engine_temp
Data Type 7,
Mask2: j1939_fuel_rate
Data Type 7
Data Type 7,
Mask2: j1939_eng_load
Data Type 7,
Mask2: can_engine_hrs
Data Type 7,
Mask2: can_taho
Data Type 7
Data Type 7
Data Type 7
Data Type 7,
Mask2: total_fuel
Data Type 7
Data Type 7,
Mask2: can_fls,
Mask2: j1939_fuel_lvl2
Data Type 7
can.j1587.dtc.lci
can.j1587.dtc.oc
can.j1587.dtc.status
can.j1587.dtc.type
can.j1939.dm1.dtc.awl
can.j1939.dm1.dtc.awl.flash
can.j1939.dm1.dtc.mil
can.j1939.dm1.dtc.mil.flash
can.j1939.dm1.dtc.pl
can.j1939.dm1.dtc.pl.flash
can.j1939.dm1.dtc.rsl
can.j1939.dm1.dtc.rsl.flash
can.j1939.dm1.dtc.sa
can.j1979.s10.dtc.sa
can.j1979.s3.dtc.sa
can.j1979.s7.dtc.sa
Data Type 7,
Mask2: j1939_srv_dist
Data Type 7
Data Type 7
Data Type 7
Data Type 7,
Mask2: can_mileage
Data Type 7,
Mask2: wheel_speed
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
engine.generator.status
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 6
event.function
Event function
Data Type 6
Data Type 7
filtered.ain
Filtered analog input value
Data Type 7
frequency.counter.din
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 9
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 6
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
tilt.status
Data Type 7
Data Type 7
Data Type 7
total.trailer.weight
Total trailer weight
Data Type 7
trailer.id
Trailer ID
Data Type 7
trailer.state.bitmask
Trailer status
Data Type 7
ussd.data
USSD data
Data Type 11
Data Type 1,
Data Type 7
wiegand.code
Wiegand26 RFID code
Data Type 7
Fmset Force
fmset
Force Create Socket to Fmset
Activate output 1
type: Pulse Type
Activate output 2
type: Pulse Type
Output 3
output3
Activate output 3
type: Pulse Type
Signal 1
signal1
Static Signal 1
Signal 2
signal2
Static Signal 2
