Cargo Spy (CS1)
Cargo Spy is an autonomous asset GPS tracker with high capacity battery and IP65 water-resistant casing. The device features a 5000mAh (or 7000mAh in Plus version) battery, optional neodymium magnets, optional SOS button, dual SIM support. The tracker can operate in the beacon mode for up to two months, and in the always-on mode for up to two weeks.
Parameters (46)
Settings (13)
Cargo Spy (CS1)
Flespi parses telemetry data from your Cargo Spy (CS1) into a standardized JSON and lets you send commands to Cargo Spy (CS1) via API.
    "device.type.id": "Cargo Spy (CS1)",
    "protocol.id": "cargo"
How to send commands to Cargo Spy (CS1)?
AVL ID 9
case.status
Case opened status
AVL ID 7
AVL ID 4
AVL ID 1
AVL ID 66
AVL ID 130
AVL ID 132
AVL ID 205
AVL ID 206
AVL ID 133
AVL ID 24
AVL ID 69
AVL ID 109,
AVL ID 2
trailer.id
Trailer ID
AVL ID 135
AVL ID 199
APN SIM1
apn1
APN settings for SIM1
APN SIM2
apn2
APN settings for SIM2
Block/Unblock Engine
block_engine
Block/unblock engine
block: Block
Bluetooth
Enable/disable bluetooth.
Clear Buffer
clear_buffer
Configuration
config
info: Configuration
Location
location
Query device location
info: Location
Reboot the device.
Reset
Sensors
sensors
Query device sensors state
info: Sensors
Backend Server
Backend server setup
Mode
track2
Tracking configuration
Query device version
info: Version
payload: Command payload as text or HEX string
Query device configuration
{"payload":"@info:conf@"}
custom_no_response
