Cargo Unit (CU2)
Cargo Unit (CU2) is a personal GPS tracker with an optional SOS button. The device features three operation modes, a built-in accelerometer, 1200mAh battery, compact casing, and more.
Parameters (46)
Settings (13)
Cargo Unit (CU2)
Flespi parses telemetry data from your Cargo Unit (CU2) into a standardized JSON and lets you send commands to Cargo Unit (CU2) via API.
    "device.type.id": "Cargo Unit (CU2)",
    "protocol.id": "cargo"
How to send commands to Cargo Unit (CU2)?
AVL ID 9
case.status
Case opened status
AVL ID 7
AVL ID 4
AVL ID 1
AVL ID 66
AVL ID 130
AVL ID 132
AVL ID 205
AVL ID 206
AVL ID 133
AVL ID 24
AVL ID 69
AVL ID 109,
AVL ID 2
trailer.id
Trailer ID
AVL ID 135
AVL ID 199
APN SIM1
apn1
APN settings for SIM1
APN SIM2
apn2
APN settings for SIM2
Block/Unblock Engine
block_engine
Block/unblock engine
block: Block
Bluetooth
Enable/disable bluetooth.
Clear Buffer
clear_buffer
Configuration
config
info: Configuration
Location
location
Query device location
info: Location
Reboot the device.
Reset
Sensors
sensors
Query device sensors state
info: Sensors
Backend Server
Backend server setup
Mode
track3
Tracking configuration
Query device version
info: Version
payload: Command payload as text or HEX string
Query device configuration
{"payload":"@info:conf@"}
custom_no_response
