Cellocator CelloTrack
Cellocator CelloTrack is an advanced asset tracking and remote monitoring solution suitable for all types of fleet management applications. The device supports 2G and 3G networks connectivity and features GPS and GLONASS positioning engines, built-in 3D accelerometer, geo-fencing, high performance Li-Pol rechargeable battery, and IP67-compliant casing.
Parameters (255)
Commands (4)
Flespi parses telemetry data from your Cellocator CelloTrack into a standardized JSON and lets you send commands to Cellocator CelloTrack via API.
    "device.type.id": "Cellocator CelloTrack",
    "protocol.id": "cellocator"
How to send commands to Cellocator CelloTrack?
acceleration.rms
Module 28,
Module 32
accelerometer.idling.duration
Module 60
Message Type 0,
Module 41
altitude.difference
Module 28
Module 90
battery.state.bitmask
Module 90
Module 90
baud.rate.enum
Used baud-rate enum value
Module 28
calibration.matrix.index
Module 43
calibration.phase
Calibration phase, 1 or 2
Module 70
calibration.state.enum
Module 70
calibration.status
Module 30,
Module 70
calibration.step
Calibration step, 0 - 10
Module 70
Module 1,
Module 38
Module 1,
Module 38
can.dtc.source
Module 38
can.dtc.state.bitmask
Module 38
can.pending.dtc
Module 1
Module 70
Module 35,
Module 63
Module 70
crash.id
Crash ID
Module 35,
Module 63
Module 35,
Module 63
crash.movement.status
Module 70
crash.orientation
Crash orientation
Module 35,
Module 63
Module 35,
Module 63
csa.event.reason
CSA event reason
Module 30
csa.event.seqnum
CSA event numerator
Module 30
csa.event.subreason
CSA event subreason
Module 30
device.battery.level
Device battery level
Module 42
Message Type 11
device.illuminance
Module 42
device.io.bitmask
Message Type 0,
Module 41
device.pressure.altitude
Module 42
Module 42
device.temperature.valid
Temperature readings validity
Module 42
device.x.acceleration
Module 42
device.y.acceleration
Module 42
device.z.acceleration
Module 42
Module 30,
Module 32,
Module 70
driving.status
Driving status
Module 30,
Module 35,
Module 63
Module 70
engine.on.idling.duration
Module 60
engine.status
Engine status
Module 30
event.category
Event category
Module 28
Module 28
external.alarm.status
External alarm status
Message Type 0
external.memory
Message Type 9
external.memory.type.enum
Message Type 9
forwarded.message.code
Forwarded Message Code
Message Type 8
fragment.control.byte
Fragment Control Byte
Message Type 8
free.fall.event
Free fall evemt detected
Module 28
Message Type 9
Message Type 9
gnss.idling.duration
Module 60
Message Type 0,
Message Type 9,
Module 41
gps.mode
GPS mode
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 9
Message Type 9,
Module 46
Message Type 9,
Module 46
Message Type 0,
Module 4,
Module 41,
Module 46
Message Type 0,
Module 4,
Module 41,
Module 46
Message Type 0,
Module 41
Module 46
gsm.pcid
Module 46
Message Type 9,
Module 42,
Module 90
Message Type 9
gsm.timestamp
Module 46
hardware.interface.enum
Message Type 9
hardware.type
Hardware type
Message Type 0
hardware.version.enum
Hardware version enum
Message Type 0,
Message Type 11,
Message Type 9
Module 70
Module 70
harsh.turn.event
Harsh turn event detected
Module 70
Module 70
Module 70
Message Type 0
ignition.on.idling.duration
Module 60
impact.event
Impact event
Module 28
internal.memory
Message Type 9
long.idling.duration
Module 60
mandown.event
Mandown event detected
Module 28
maneuver.abs.state
Module 31
maneuver.average.speed
Maneuver average speed
Module 31,
Module 58,
Module 61
maneuver.average.speed.green
Average speed in zone Green
Module 58
maneuver.average.speed.red
Average speed in zone Red
Module 58
maneuver.average.speed.yellow
Average speed in zone Yellow
Module 58
maneuver.delta.speed
Maneuver speed delta
Module 31,
Module 58
maneuver.duration
Maneuver duration
Module 31,
Module 58,
Module 60,
Module 61,
Module 63,
Module 75
maneuver.engine.rpm.average
Module 58
maneuver.engine.rpm.max
Max engine RPM in maneuver
Module 31,
Module 58
Module 75
maneuver.harsh.braking.event
Module 75
maneuver.harsh.turn.angle
Module 75
Module 75
Module 75
maneuver.id
Maneuver id
Module 30,
Module 31,
Module 58,
Module 60,
Module 61,
Module 63
maneuver.max.fuel.flow
Module 31
maneuver.max.speed
Maneuver max speed
Module 31,
Module 58,
Module 61,
Module 75
maneuver.overspeeding.event
Module 75
maneuver.risk.score
Maneuver risk value 0-100
Module 31,
Module 58
maneuver.start.latitude
Module 31,
Module 58,
Module 60,
Module 61,
Module 63,
Module 75
maneuver.start.longitude
Module 31,
Module 58,
Module 60,
Module 61,
Module 63,
Module 75
maneuver.start.position.valid
Module 75
maneuver.start.timestamp
Module 75
maneuver.stop.latitude
Module 31,
Module 58,
Module 60,
Module 61,
Module 63,
Module 75
maneuver.stop.longitude
Module 31,
Module 58,
Module 60,
Module 61,
Module 63,
Module 75
maneuver.stop.position.valid
Module 75
maneuver.stop.timestamp
Module 75
maneuver.time.green
Time in maneuver zone Green
Module 58
maneuver.time.red
Time in maneuver zone Red
Module 58
maneuver.timestamp
Maneuver start time timestamp
Module 31,
Module 58,
Module 60,
Module 61,
Module 63
maneuver.time.yellow
Time in maneuver zone Yellow
Module 58
maneuver.total.events.green
Module 58
maneuver.total.events.red
Module 58
maneuver.total.events.yellow
Module 58
maneuver.total.fuel.flow
Integral of Fuel flow
Module 31
maneuver.total.severity.enum
Module 58
maneuver.type
Maneuver type
Module 31,
Module 58,
Module 60,
Module 61,
Module 63
Accelerometer X axes average
Module 31
maneuver.x.acceleration.max
Module 31,
Module 58,
Module 61,
Module 75
Accelerometer Y axes average
Module 31
maneuver.y.acceleration.max
Module 31,
Module 58,
Module 61,
Module 75
maneuver.z.acceleration.max
Module 31,
Module 58,
Module 61
measurement.source
Source of measurement
Module 28,
Module 40
modem.type.enum
Modem type
module.id
Message Type 11
Module 46
Message Type 9
Message Type 9
operation.mode
Unit's operation mode
Message Type 0,
Module 41
operation.mode.enum
Message Type 0,
Module 41
operator.id
Module 2,
Module 25
Module 70
Message Type 7,
Message Type 8
pl.signature
Module 2
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 11,
Module 30,
Module 6
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6
Message Type 9
processor.enum
Processor family identifier
Message Type 9
program.memory
Size of program memory
Message Type 9
Message Type 0,
Module 41
Message Type 0,
Module 41
report.reason.data
Additional transmission data
Message Type 0,
Module 41
Message Type 0,
Module 41
rollover.alarm.status
Roll over alarm state
Module 70
Module 35,
Module 63
row.logging.status
Row logging status
Module 30
samples.after.crash
Module 35
samples.before.crash
Module 35
secondary.engine.status
Standby engine status
Module 30
sensor.battery.dead.status
Module 28
sensor.battery.level
External sensor battery level
Module 28
Module 44
sensor.battery.low.status
Module 28
sensor.battery.voltage
Sensor battery voltage
Module 28
sensor.connected.status
Module 28
Module 28
sensor.error.code
Sensor problem code
Module 28
sensor.group.id
Sensor group ID
Module 28
Module 28
sensor.humidity.additional
Module 44
sensor.humidity.alert
Sensor humidity alert
Module 28
Module 28
sensor.illuminance.additional
Module 44
sensor.last.timestamp
Module 28
Module 44
sensor.mac.address
External sensor MAC address
Module 28
sensor.mac.address.additional
Module 44
Module 28
Module 44
sensor.package.status
Module 28
Module 44
sensor.paired.status
Module 28
sensor.power.on.status
Module 28
sensor.reading.age
Module 28
sensor.readings
sensor.readings.type
Module 40
sensor.report.reason
Module 28
sensor.rssi
dBm
Sensor RSSI
Module 28
sensor.rssi.additional
dBm
Module 44
Module 28
sensor.temperature.additional
Module 44
sensor.temperature.alert
Sensor temperature alert
Module 28
sensor.type.bitmask
Sensor HW type bitmask
Module 28
sensor.x.acceleration
Module 28
Module 44
sensor.y.acceleration
Module 28
Module 44
sensor.z.acceleration
Module 28
Module 44
sensor.zone
Sensor zone number
Module 28
serial.port.source
Serial Port Source
Message Type 8
short.idling.duration
Module 60
Message Type 0
software.version.enum
Software version enum
Message Type 9
speed.source
Message Type 0,
Module 41
time.after.crash
Module 35
time.before.crash
Module 35
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6,
Module 7
Message Type 0,
Message Type 11,
Message Type 9,
Module 30,
Module 6,
Module 7
time.valid.status
Time is accurate
Message Type 0,
Message Type 11,
Message Type 9,
Module 41,
Module 6,
Module 7
trailer.id
Trailer ID
Message Type 0
trigger.cause.enum
Module 25
Module 32
Module 32
trip.eco.score
Module 32
trip.engine.time
Trip delta engine time
Module 32
Message Type 9
trip.highway.driving.score
Module 32
trip.highway.score.time
Module 32
Module 30,
Module 31,
Module 32,
Module 58,
Module 60,
Module 61,
Module 63
trip.idle.fuel.consumed
Trip idle fuel consumption
Module 32
trip.idle.score
Idle score of the trip
Module 32
trip.idle.score.time
Idle score time of the trip
Module 32
trip.long.idle.time
Module 32
Module 32
Module 32
trip.movement.fuel.consumed
Module 32
Module 32
trip.safety.score
Module 32
trip.short.idle.time
Module 32
trip.start.fuel.level
Fuel level upon trip start
Module 32
Module 32
trip.stop.fuel.level
Fuel level upon trip end
Module 32
trip.stop.mileage
Trip end odometer value
Module 32
trip.urban.driving.score
Module 32
trip.urban.score.time
Module 32
trip.x.acceleration.max
Module 32
trip.y.acceleration.max
Module 32
trip.z.acceleration.max
Module 32
variable.data.hex
Module 2
variable.id
Module 2
Message Type 0,
Message Type 9,
Module 41
vehicle.odometer
Message Type 0,
Message Type 9,
Module 41
Module 35,
Module 63
volatile.memory
Size of volatile memory
Message Type 9
work.id
Work ID counter
Module 28
Generic Command
custom_message_type_0
code: Command code
data1: Command data field 1
data2: Command data filed 2
Reset device
{"code":2,"data1":2}
Request status from device
{"code":0}
Commence gradual engine stop
{"code":7}
{"code":5,"data1":4}
Programming command
custom_message_type_1
block: Block code number
Modular Message Request
custom_message_type_9
data: Sub-Data
type: Sub-Data type
CAN data request
{"type":2}
Firmware manifest request
{"type":1}
{"type":4}
Output state change
output
Output state change
Set Output 0 (siren) ON
{"state":true,"ordinal":0}
