Coban GPS303-H
Coban GPS303-H is a vehicle 2G/3G GPS tracker working based on existing GSM/GPRS networks (850/900/1800/1900Mhz) and GPS satellites. The device features voice monitor, low battery alarm, external power off alarm, GPS blind-spot alert, SOS, geo-fencing, multiple area management, movement alarm, overspeeding alarm, ACC working alarm, fuel alarm, remote cut off the oil and power system, sleep mode, configuration over USB, and more.
Parameters (61)
Settings (4)
Coban GPS303-H
Flespi parses telemetry data from your Coban GPS303-H into a standardized JSON and lets you send commands to Coban GPS303-H via API.
    "device.type.id": "Coban GPS303-H",
    "protocol.id": "coban"
How to send commands to Coban GPS303-H?
acc.alarm
ACC alarm event
Keyword: acc alarm
armed.status
Armed/disarmed status
Keyword: status
arm.status
Keyword: 111,
Keyword: 112,
Keyword: 512,
Keyword: lf,
Keyword: lt,
Keyword: mt
Keyword: low battery
Keyword: OBD
Keyword: OBD
Keyword: OBD
Keyword: OBD
Keyword: OBD
Keyword: OBD
can.onboard.power.voltage
CAN onboard power voltage
Keyword: OBD
Keyword: OBD
Keyword: OBD
Keyword: OBD
Keyword: OBD
Keyword: door alarm
Keyword: 109,
Keyword: 110,
Keyword: jt,
Keyword: kt
Keyword: acc off,
Keyword: acc on
fuel.alarm
Fuel alarm event
Keyword: oil
Keyword: stockade
Keyword: accelerate
Keyword: brake,
Keyword: brake alarm
harsh.turn.event
Harsh turn event detected
Keyword: sharp turn
Keyword: move
Keyword: speed
Keyword: ac alarm
Keyword: status
Keyword: help me
Keyword: T
Keyword: collision
Keyword: sensor alarm
Arm/Disarm
arm
Arm and disarm the device
arm: Arm/Disarm
format: Format
Block Engine
block_engine
format: Format
cut_off: Cut Off
timezone
Set time zone for device
shift: Time Zone
Tracking
tracking
Enable tracking
Set geofence
Set server IP:port
Cut off oil and power
{"payload":"109"}
