Jimi IoT (Concox) JM-VG02U
Concox JM-VG02U is an insurance OBD GPS tracker for UBI applications. The device features 8 types of driver behavior analysis, remote power/fuel cut-off, and more.
Parameters (355)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VG02U into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VG02U via API.
    "device.type.id": "Jimi IoT (Concox) JM-VG02U",
How to send commands to Jimi IoT (Concox) JM-VG02U?
Protocol Number 0x39
Protocol Number 0x15
