Jimi IoT (Concox) JM-VL106
The VL106 is an advanced vehicle tracker with a synergistic blend of GNSS (including GPS/BDS/GLONASS/Galileo) and INS for precise positioning, even without satellite signals. It features driving behavior analysis, collision detection, multiple alerts, remote fuel/power cutoff, SOS button, and ACC ignition detection. The device operates well in tough environments, facilitated by its IP65 rating and is equipped with a 3-axis accelerometer and a 3-axis gyroscope, a small backup battery, and INS accuracy of less than 2%.
Parameters (356)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL106 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL106 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL106",
How to send commands to Jimi IoT (Concox) JM-VL106?
Protocol Number 0x39
Protocol Number 0x15
