Jimi IoT (Concox) JM-VL512
The VL512 is a vehicle 4G LTE OBDII tracker with 2G GSM fallback perfect for fleet management. It provides effortless installation, GPS+BDS positioning, multiple alerts for vehicle monitoring, and a remote listen-in feature. The device supports LTE Cat 1 + GSM networks, withstands extreme temperatures, and has a compact design with a built-in industrial-grade battery.
Parameters (366)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL512 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL512 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL512",
How to send commands to Jimi IoT (Concox) JM-VL512?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
