Eelink TK319
Eelink TK319 is a 3G GPS tracker with GPIO extension and optional temperature sensor. The device features ACC detection, cut engine relay, speed alarm, geo-fence alarm, collision/falling alarm, vibration alarm, 140mAh battery, IP65 waterproof casing, and more.
Parameters (79)
Settings (22)
Eelink TK319
Flespi parses telemetry data from your Eelink TK319 into a standardized JSON and lets you send commands to Eelink TK319 via API.
    "device.type.id": "Eelink TK319",
    "protocol.id": "eelink"
How to send commands to Eelink TK319?
burnt.enery
calories
Accumulated burnt energy today
carbon.dioxide.alarm
CO2 concentration if out of predefined range
carbon.dioxide.ppm
Carbon dioxide concentration
gnss.antenna.open.circuit.status
GNSS antenna open-circuit status
illuminance.alarm
Illuminance if out of predefined range
message.content
Message content
pet.activity.duration
Duration of the pet activity state segment
pet.activity.state
Pet activity state (sleep, rest, walk, run)
pet.activity.state.enum
Pet activity state code
pet.rest.time
Pet resting time for the day
pet.run.time
Pet running time for the day
pet.sleep.time
Pet sleeping time for the day
pet.walk.time
Pet walking time for the day
report.timestamp
Report timestamp
sensor.temperature.alarm
Sensor temperature value is out of predefined ranges
total.burnt.enery
calories
Accumulated burnt energy in total
total.steps.count
Accumulated steps count in total
total.walk.distance
Accumulated walking distance in total
total.walk.time
Accumulated walking time in total
underspeed.event
Underspeed event
walk.distance
Accumulated walking distance today
walk.time
Accumulated walking time today
wifi.fence.mac.address
MAC address (BSSID) of the Wi-Fi fence access point
wifi.fence.signal.strength
Signal strength (RSSI) of the Wi-Fi fence access point
wifi.fence.ssid
SSID of the Wi-Fi fence access point
wifi.home.status
Home Wi-Fi location flag
AGPS Server Setup
agps
AGPS server configuration
uri: AGPS Server URI
Network Setup
GPRS network configuration
apn_password: APN Password
apn_username: APN Username
Parameters of Location Collection
collect
This command requests to change the parameters of location collection. All parameters define how to collect location package and how many location packages to be cached before they are sent to server.
turn: Turn
active: Active
distance: Distance
quantity: Quantity
imei: Device IMEI
imsi: SIM IMSI
build: Firmware Build Time
iccid: SIM ICCID
os_ver: Operation System Version
app_ver: Application Version
Geofence 1
fence1
fence: Geofence Shape
Geofence 2
fence2
Geofence 3
fence3
Geofence 4
fence4
Geofence 5
fence5
Geofence 6
fence6
Geofence 7
fence7
Geofence 8
fence8
GPS Module
gps
Change the work mode and parameters of GPS module. It defines how and when GPS module switches in 2 states. GPS module has 2 states: ON and OFF. When GPS module is OFF, GPS chip is closed. Normally, we can use this command to save a lot of power consumption.
t0: Work time
gps_run: Running time from last GPS command
t1_total: Total time of phase 1
t1_waking: Work time in phase 1
t2_waking: Work time in phase 2
t2_periodic: periodic time of phase 2
Manager 1
manager1
manager: Enable
Manager 2
manager2
manager: Enable
Manager 3
manager3
manager: Enable
Manager 4
manager4
manager: Enable
Motion Alarm
motion_alarm
motion_alarm: Motion Alarm
Relay Control
relay
relay: Enable
Server Setup
Backend server configuration
uri: Backed Server URI
Shift Fence
shift_fence
shift_fence: Shift Fence
Speed Alarm
speed_alarm
low_alarm: Low Speed Alarm
high_alarm: High Speed Alarm
speed_relay: Speed Relay Feature
Set heartbeat timer to 5 minutes
{"payload":"HBT,5#"}
Change time zone of the device to UTC
{"payload":"GMT,E,0,0,0#"}
