iTriangle Bharat 101
iTriangle Bharat 101 is an AIS-140 certified vehicle GPS/GLONASS tracker designed for fleet management and vehicle tracking applications in India. First device in India certified under AIS 140 standard, it features a compact rugged IP67 enclosure, multi-constellation GNSS positioning (GPS, GLONASS, BeiDou, Galileo, IRNSS), and 2G/GPRS connectivity. The device includes an 850mAh internal backup battery, 3-axis accelerometer and gyrometer for driving behavior monitoring (harsh braking, acceleration, cornering), RS-232 serial port, 4 digital inputs, 2 digital outputs, and 2 analog inputs. Equipped with embedded SIM with dual network switching, panic button support, and internal antennas for stealth installation, it operates on wide DC voltage range (9-32V) and stores up to 41,000 tracking records.
Parameters (60)
Flespi parses telemetry data from your iTriangle Bharat 101 into a standardized JSON and lets you send commands to iTriangle Bharat 101 via API.
    "device.type.id": "iTriangle Bharat 101",
    "protocol.id": "itriangle"
How to send commands to iTriangle Bharat 101?
accident.event
Accident event detected
case.status
Case opened status
device.tamper.status
event.name
Protocol-specific event name
flash.memory.level
Flash memory used
gsm.network.name
tilt.status
Set server address (4G)
{"payload":"114:ms1.aquilatrack.com"}
Activate digital output 1
{"payload":"SET_DO1:1"}
