iTriangle TS101 Basic
iTriangle TS101 Basic is a compact 2G vehicle tracking and fleet management device designed for real-time GPS tracking applications. The device features quad-band GSM/GPRS connectivity, internal GNSS antenna with SBAS support, and an IP65-rated rugged casing for durability. It includes a 700mAh Li-Ion backup battery, multiple I/O ports (1 digital input, 1 digital output, 1 analog input, and dedicated ignition input), and operates on a wide 9-32V power range. The tracker stores up to 10,000 tracking records in 4MB flash memory and supports harsh driving detection, over-the-air firmware updates, remote configuration, and various fleet management features including odometer tracking and immobilization control.
Parameters (60)
Settings (4)
Flespi parses telemetry data from your iTriangle TS101 Basic into a standardized JSON and lets you send commands to iTriangle TS101 Basic via API.
    "device.type.id": "iTriangle TS101 Basic",
    "protocol.id": "itriangle"
How to send commands to iTriangle TS101 Basic?
accident.event
Accident event detected
case.status
Case opened status
device.tamper.status
event.name
Protocol-specific event name
flash.memory.level
Flash memory used
gsm.network.name
tilt.status
GPRS Settings
gprs
This command configures the GPRS settings
address: IP Address/DNS
Transmission interval
interval
This command is used to configure the transmission interval
on_int: ON interval
off_int: OFF interval
link_type: Link type
Output control
output
Output control command
type: Type
Soft restart command
Set server address (4G)
{"payload":"114:ms1.aquilatrack.com"}
Activate digital output 1
{"payload":"SET_DO1:1"}
