iTriangle TS101 Basic EV CAN
iTriangle TS101 Basic EV CAN is a compact vehicle tracking and fleet management device specifically designed for electric vehicles and CAN networks. It features built-in CAN bus capability, multiple I/O ports, and IP65 rugged casing for durability. The device operates on a wide 9-90V power supply range and stores up to 6000 tracking records. With GNSS+GLONASS positioning, internal battery backup, Bluetooth connectivity, and AIS 140 certification, it provides comprehensive fleet oversight. The device includes motion sensors, remote diagnostics capabilities, and is ideal for electric vehicle fleets, municipal vehicles, two-wheelers, logistics, and fleet tracking applications.
Parameters (60)
Settings (4)
Flespi parses telemetry data from your iTriangle TS101 Basic EV CAN into a standardized JSON and lets you send commands to iTriangle TS101 Basic EV CAN via API.
    "device.type.id": "iTriangle TS101 Basic EV CAN",
    "protocol.id": "itriangle"
How to send commands to iTriangle TS101 Basic EV CAN?
accident.event
Accident event detected
case.status
Case opened status
device.tamper.status
event.name
Protocol-specific event name
flash.memory.level
Flash memory used
gsm.network.name
tilt.status
GPRS Settings
gprs
This command configures the GPRS settings
address: IP Address/DNS
Transmission interval
interval
This command is used to configure the transmission interval
on_int: ON interval
off_int: OFF interval
link_type: Link type
Output control
output
Output control command
type: Type
Soft restart command
Set server address (4G)
{"payload":"114:ms1.aquilatrack.com"}
Activate digital output 1
{"payload":"SET_DO1:1"}
