Jimi IoT (Concox) JM-LL306
The Jimi IoT LL306 is a 4G LTE container GNSS tracker with global roaming, remote configuration, and a magnetic mount. It features IP65 dust and water resistance, optional environment detection, and a 60-day working time in static mode. The device includes door status detection, installation/remove alerts, and SOS number settings. It supports automatic and manual mode switching for static, land, and sea transportation modes, with customizable GPS positioning intervals. The tracker is equipped with a micro USB charging port and provides alerts for low battery, door open/close, and mode switching.
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL306 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL306 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL306",
How to send commands to Jimi IoT (Concox) JM-LL306?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Message ID 0x0800
