Kingwo LT12
LT12-GPS Container Tracking is a 4G LTE asset tracker designed for container and asset monitoring. It features a long-lasting 10800mAh battery with up to 8 years of life (uploading once daily), internal high-gain GPS and GSM antennas, IP67 waterproof rating, and accurate GPS positioning (5-10m). The device is shaped like a container air vent for discreet installation and operates in extreme temperatures (-20℃ to +70℃).
Parameters (89)
Settings (6)
Kingwo LT12
Flespi parses telemetry data from your Kingwo LT12 into a standardized JSON and lets you send commands to Kingwo LT12 via API.
    "device.type.id": "Kingwo LT12",
    "protocol.id": "kingwo"
How to send commands to Kingwo LT12?
Addition data d
Addition data K
Addition data T
Addition data B,
Addition data K
Addition data e
Function GB,
Function GD,
Function GM,
Function GT
communication.interupted
Communication interupted
Addition data P
Addition data B
device.id.number.error
Addition data P
Addition data W
domain.name.error
Addition data P
Addition data B
downloading.agps
Downloading AGPS data
Addition data P
Addition data B
Function AW
Addition data H
Lock event 14,
Lock event 15
gps.jamming.event
GPS signal jamming detected
Addition data K
gps.module.error
GPS module error flag
Addition data B
g.sensor.error
G-sensor error
Addition data K
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data R
Addition data Z
Addition data Z
Addition data Z
Addition data Z
improper.installation
Addition data K
ip.error
Addition data P
lock.device.code
Lock device code
Report type 7 of Function RP
lock.failure.alarm
Locking failure alarm event
Addition data l
lock.state
Addition data l
Lock event 0,
Lock event 1
Addition data V
Addition data K
module.error.no.response
Module error, No response
Addition data P
Addition data K
Addition data B
network.register.failure
Network register failure
Addition data P
network.type
Network type
Addition data N
nfc.code
NFC card code (UID)
no.signal
No signal
Addition data P
Addition data B
Function BT
pdp.activation.context.failed
PDP activation context failed
Addition data P
Addition data G
Addition data A
Addition data A
Addition data A
Addition data R
Addition data A,
Addition data F
Addition data A
Addition data B
Addition data K
removal.status
Removal satus
Addition data K
reset.reason
Device reset reason
Addition data K
rtc.error
RTC Error
Addition data K
Addition data M
Addition data J
sim.card.error
Addition data P
Addition data B
spi.flash.fault
SpiFlash fault
Addition data K
steel.string.cut.alarm
Steel string cut alarm
Addition data l
Addition data A,
Function GB,
Function GD,
Function GT,
Report type 4 of Function RP
track.mode
Track mode
Addition data K
Report type 0 of Function RP
unlock.event
Unlock event
Lock event 1
Addition data Z,
Addition data C
Addition data B
Addition data Q
wifi.module.error
WIFI module error
Addition data K
Addition data Q
Device firmware version and BLE MAC address.
ble_mac: BLE MAC address
version: Firmware version
Positioning priority
positioning_priority
Positioning mode priority.
Removal alarm
removal_alarm
Removal alarm switch and behavior.
SIM ICCID
sim_iccid
SIM card ICCID.
iccid: ICCID
Sleep interval
sleep_interval
Upload interval in sleep/latent mode, in minutes.
interval: Interval in minutes
Timezone
timezone
Device timezone offset in minutes. Highest bit indicates west (negative) timezone.
offset_minutes: Offset in minutes
Custom text command
text: Text payload
storage: Storage property
function: Function
response: Response property
More devices from Shenzhen Kingwo Iot Co. , Ltd. (8)
