Kingwo NT52
NT52-4G Cat1 Vehicle GPS Tracker is a specialized positioning device designed for vehicles, featuring real-time tracking with LTE Cat1 connectivity. It includes a built-in 300mAh polymer lithium battery for backup power and supports extended interfaces for tire pressure, temperature, door sensors, and pressure switches, making it suitable for comprehensive vehicle monitoring and management.
Parameters (89)
Settings (6)
Kingwo NT52
Flespi parses telemetry data from your Kingwo NT52 into a standardized JSON and lets you send commands to Kingwo NT52 via API.
    "device.type.id": "Kingwo NT52",
    "protocol.id": "kingwo"
How to send commands to Kingwo NT52?
Addition data d
Addition data K
Addition data T
Addition data B,
Addition data K
Addition data e
Function GB,
Function GD,
Function GM,
Function GT
communication.interupted
Communication interupted
Addition data P
Addition data B
device.id.number.error
Addition data P
Addition data W
domain.name.error
Addition data P
Addition data B
downloading.agps
Downloading AGPS data
Addition data P
Addition data B
Function AW
Addition data H
Lock event 14,
Lock event 15
gps.jamming.event
GPS signal jamming detected
Addition data K
gps.module.error
GPS module error flag
Addition data B
g.sensor.error
G-sensor error
Addition data K
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data I,
Addition data Y
Addition data R
Addition data Z
Addition data Z
Addition data Z
Addition data Z
improper.installation
Addition data K
ip.error
Addition data P
lock.device.code
Lock device code
Report type 7 of Function RP
lock.failure.alarm
Locking failure alarm event
Addition data l
lock.state
Addition data l
Lock event 0,
Lock event 1
Addition data V
Addition data K
module.error.no.response
Module error, No response
Addition data P
Addition data K
Addition data B
network.register.failure
Network register failure
Addition data P
network.type
Network type
Addition data N
nfc.code
NFC card code (UID)
no.signal
No signal
Addition data P
Addition data B
Function BT
pdp.activation.context.failed
PDP activation context failed
Addition data P
Addition data G
Addition data A
Addition data A
Addition data A
Addition data R
Addition data A,
Addition data F
Addition data A
Addition data B
Addition data K
removal.status
Removal satus
Addition data K
reset.reason
Device reset reason
Addition data K
rtc.error
RTC Error
Addition data K
Addition data M
Addition data J
sim.card.error
Addition data P
Addition data B
spi.flash.fault
SpiFlash fault
Addition data K
steel.string.cut.alarm
Steel string cut alarm
Addition data l
Addition data A,
Function GB,
Function GD,
Function GT,
Report type 4 of Function RP
track.mode
Track mode
Addition data K
Report type 0 of Function RP
unlock.event
Unlock event
Lock event 1
Addition data Z,
Addition data C
Addition data B
Addition data Q
wifi.module.error
WIFI module error
Addition data K
Addition data Q
Device firmware version and BLE MAC address.
ble_mac: BLE MAC address
version: Firmware version
Positioning priority
positioning_priority
Positioning mode priority.
Removal alarm
removal_alarm
Removal alarm switch and behavior.
SIM ICCID
sim_iccid
SIM card ICCID.
iccid: ICCID
Sleep interval
sleep_interval
Upload interval in sleep/latent mode, in minutes.
interval: Interval in minutes
Timezone
timezone
Device timezone offset in minutes. Highest bit indicates west (negative) timezone.
offset_minutes: Offset in minutes
Custom text command
text: Text payload
storage: Storage property
function: Function
response: Response property
More devices from Shenzhen Kingwo Iot Co. , Ltd. (8)
