Meitrack MD533S
Meitrack MD533S is a small-size and light-weight MDVR device that can operate in vehicle tracking mode and video recording mode simultaneously. The device features 4G communication, 2-channel 1080P live video recording, video management via Wi-Fi, multiple audio inputs and outputs, and more.
Parameters (174)
Settings (10)
Commands (6)
Meitrack MD533S
Flespi parses telemetry data from your Meitrack MD533S into a standardized JSON and lets you send commands to Meitrack MD533S via API.
    "device.type.id": "Meitrack MD533S",
    "protocol.id": "meitrack"
How to send commands to Meitrack MD533S?
Command type AAA
adas.blindspot.side
Command type AAA
Command type AAA,
Command type AAA,
Command type AAA
Command type AAA
Command type AAA,
Command type AAA
Command type AAA,
Command type CCC,
alarm.camera.type
Command type CCE,
Command type CFF
alarm.camera.type.enum
Command type CCE,
Command type CFF
alarm.files
Command type AAA,
Command type AAA
Command type AAA,
Command type CCC,
ble.disconnected.alarm
BLE disconnected alert
Command type AAA
call.duration
Call duration
call.timestamp
Call timestamp
call.type
Call type
Command type AAA,
call.type.enum
Call type number
Command type AAA
device.installed.status
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
dsm.driver.staring.event
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCE,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type CE0
Command type AAA
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA
fuel.full.event
Fuel tank full event
Command type AAA
Command type AAA
fuel.refuelling.event
Command type AAA
fuel.theft.alarm
Fuel Theft Alarm
Command type AAA
Command type CCC,
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA
magnetic.card.data
Magnetic card data
maintenance.required.event
Command type AAA
maneuver.average.speed
Maneuver average speed
maneuver.duration
Maneuver duration
maneuver.max.speed
Maneuver max speed
maneuver.overspeeding.event
maneuver.start.latitude
maneuver.start.longitude
maneuver.start.timestamp
maneuver.stop.latitude
maneuver.stop.longitude
maneuver.stop.timestamp
Command type AAA,
network.description
Network description
network.type
Network type
Command type AAA
Command type 110,
Command type CE0
Command type CE0
picture.event
Picture event
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA
reboot.event
Device reboot event
Command type AAA
Command type AAA,
Command type AAA
Command type AAA,
Command type AAA
speed.data
speed.data.interval
Interval between speed values
storage.full.status
Storage is full, indexed
Command type AAA
storage.media.malfunction
Command type AAA
tacho.performance
Tachograph performance
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
vehicle.battery.voltage
Vehicle battery voltage
Command type AAA,
Command type CCC,
vibration.status
Command type AAA
Audio codec
audio_codec
codec: Codec
Authorize RFID/iButton key
auth_rfid
value: RFID/iButton key
Delete RFID/iButton key
delete_rfid
Generic device information.
serial: Serial Number
firmware: Firmware Version
FTP configuration
ftp_configuration
path: Path
address: Address
operate: Mode
username: Username
GPRS Event transmit mode
gprs_event_transmit_mode
value: Event mode
List of RFID/iButton keys
rfids
list: RFID/iButton keys list
Server Settings Setup
GPRS Time Zone
timezone
shift: Time Zone
Local Time Zone
timezone_local
Local time zone
shift: Time Zone
{"command_type":"A10"}
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
