Meitrack MD811H
Meitrack MD811H is a 8-channel 1080P MDVR device that can operate in vehicle tracking mode and video recording mode simultaneously. The device features 4G communication, video management via Wi-Fi, multiple audio inputs and outputs, H.264 video compression/ decompression, 1 SD card, 1 SATA hard drive/SSD hard drive, GPS positioning, and more.
Parameters (174)
Settings (10)
Commands (6)
Meitrack MD811H
Flespi parses telemetry data from your Meitrack MD811H into a standardized JSON and lets you send commands to Meitrack MD811H via API.
    "device.type.id": "Meitrack MD811H",
    "protocol.id": "meitrack"
How to send commands to Meitrack MD811H?
Command type AAA,
adas.blindspot.side
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
alarm.camera.type
alarm.camera.type.enum
alarm.files
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
ble.disconnected.alarm
BLE disconnected alert
Command type AAA,
call.duration
Call duration
call.timestamp
Call timestamp
call.type
Call type
Command type AAA,
call.type.enum
Call type number
Command type AAA,
device.installed.status
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
dsm.driver.staring.event
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCE,
Command type CFF,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type CCC,
Command type CE0
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
fuel.full.event
Fuel tank full event
Command type AAA,
Command type AAA,
fuel.refuelling.event
Command type AAA,
fuel.theft.alarm
Fuel Theft Alarm
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
magnetic.card.data
Magnetic card data
maintenance.required.event
Command type AAA,
maneuver.average.speed
Maneuver average speed
maneuver.duration
Maneuver duration
maneuver.max.speed
Maneuver max speed
maneuver.overspeeding.event
maneuver.start.latitude
maneuver.start.longitude
maneuver.start.timestamp
maneuver.stop.latitude
maneuver.stop.longitude
maneuver.stop.timestamp
Command type AAA,
network.description
Network description
network.type
Network type
Command type AAA,
Command type 110,
Command type CE0
Command type CE0
picture.event
Picture event
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
reboot.event
Device reboot event
Command type AAA,
Command type CCC,
Command type CCE,
Command type CFF
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
speed.data
speed.data.interval
Interval between speed values
storage.full.status
Storage is full, indexed
Command type AAA,
storage.media.malfunction
Command type AAA,
tacho.performance
Tachograph performance
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
vehicle.battery.voltage
Vehicle battery voltage
Command type AAA,
Command type CCC,
vibration.status
Command type AAA,
Audio codec
audio_codec
codec: Codec
Authorize RFID/iButton key
auth_rfid
value: RFID/iButton key
Delete RFID/iButton key
delete_rfid
Generic device information.
serial: Serial Number
firmware: Firmware Version
FTP configuration
ftp_configuration
path: Path
address: Address
operate: Mode
username: Username
GPRS Event transmit mode
gprs_event_transmit_mode
value: Event mode
List of RFID/iButton keys
rfids
list: RFID/iButton keys list
Server Settings Setup
GPRS Time Zone
timezone
shift: Time Zone
Local Time Zone
timezone_local
Local time zone
shift: Time Zone
{"command_type":"A10"}
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
