Navtelecom SIGNAL S-4752
Navtelecom SIGNAL S-4752 is a certified satellite navigation terminal (ASN) for monitoring vehicles. It meets Russian Government Decree No. 2216 and TR CU 018/2011 for M2, M3 and N category vehicles carrying dangerous goods, and it can send data to the ERA-GLONASS system. It uses external GLONASS/GPS and GSM antennas. Its 4G modem supports 2G, 3G and LTE Cat. 4, and it takes two SIM cards. A built-in 1000 mAh Li-Po battery backs up the main power. The unit supports SD cards up to 32 GB and protects its power and input lines against surges up to 200 V. It has 6 universal inputs, 4 control outputs, and RS-232, RS-485, CAN (J1939) and 1-Wire interfaces, along with MODBUS support and Complex Events logic.
Parameters (223)
Settings (24)
Flespi parses telemetry data from your Navtelecom SIGNAL S-4752 into a standardized JSON and lets you send commands to Navtelecom SIGNAL S-4752 via API.
    "device.type.id": "Navtelecom SIGNAL S-4752",
    "protocol.id": "navtelecom"
How to send commands to Navtelecom SIGNAL S-4752?
acceleration.threshold.status
accelerometer.sh1.status
accelerometer.sh2.status
accelerometer.sh3.status
accelerometer.sh4.status
accelerometer.wakeup.status
bluetooth.configurator.status
braking.threshold.status
bus.announcer.geofence.inside
bus.announcer.status
Bus announcer status
bus.counter.passengers
Bus passengers counter
bus.geofence.id
ID of last bus geofence
bus.route.id
ID of last bus route
bus.stop.id
ID of last bus stop
camera.automatic.mode.status
camera.error.event
Error working with camera
can.indicators.bitmask
can.mil.bitmask
can.security.bitmask
can.security.event.code
case.status
Case opened status
compass.position.satellites
display.driver.state.enum
display.read.message.id
doris.position.satellites
engine.generator.status
extnav.position.altitude
extnav.position.direction
extnav.position.latitude
extnav.position.longitude
extnav.position.satellites
extnav.status
freezer.active.alarm.data
Active alarms data
freezer.active.alarm.number
freezer.battery.current
Freezer battery DC current
freezer.engine.motorhours
freezer.engine.rpm
Freezer engine RPM
freezer.engine.standby.status
freezer.operating.mode
Freezer operating mode
freezer.type
Freezer type
freezer.zone1.temperature
Freezer zone 1 temperature
freezer.zone2.temperature
Freezer zone 2 temperature
freezer.zone3.temperature
Freezer zone 3 temperature
fuel.flow.meter.fuel.consumed
fuel.flow.meter.rate
fuel.flow.meters.faults.state
fuel.flow.meter.state
Fuel flow meter state bitmask
galileo.position.satellites
glonass.position.satellites
gsm.error.code
gsm.fix.age
gsm.timestamp
high.precision.humidity.level
high.precision.temperature
ins.status
iridium.status
Iridium module status
irnss.position.satellites
left.turn.threshold.status
local.vertical.tilt.angle
locator.response.enum
overspeeding.threshold.status
pitch.angle
position.source.enum
Number of position source
qzss.position.satellites
reboot.reason.bitmask
Device reboot reason bitmask
right.turn.threshold.status
roll.angle
rs232.lls.error
rs232.lls.temperature
rs485.lls.error
rs485.lls.frequency
rsc.rfu.status
RCS/RFU status
segment.valid.position.count
sensor.frequency
Frequency sensor value
sensor.uint16.value
sensor.uint32.value
sensor.uint64.value
sensor.uint8.value
server1.connection.status
Server 1 connection status
server2.connection.status
Server 2 connection status
server3.connection.status
Server 3 connection status
tacho.connection.error.status
tacho.driver.activity.enum
tacho.engine.ignition.status
Tachograph ignition state
tacho.ferry.train.enum
Tacho ferry/train status enum
tacho.mode.enum
Tachograph mode enum
tacho.na.enum
test.mode.status
threshold.exceeding.duration
timestamp.increment
timestamp.sync.status
touch.memory.id
Touch Memory Key ID
usb.connection.status
wifi.fix.age
Time since the wifi data fix
Additional Server 1
additional_server1
Additional backend server 1
addr: Server Address
dc_id: Dispatch Center ID
trans: Transport Protocol
obj_id: Object ID
protocol: Protocol
Additional Server 2
additional_server2
Additional backend server 2
obj_id: Object ID
protocol: Protocol
Calibrate Accelerometer
calibrate_accel
DRC Service
drc_conf
personal_id: Personal ID
DRC Connect
drc_connect
Connect to DRC service
time: Time
DRC Disconnect
drc_disconnect
GPRS Connection
gprs_connection
GPRS Connection configuration
apn: APN Mode
server: Server
ICCID
iccid
UIN 1
input1
Input 1 configuration
inp: Normal Line State
UIN 2
input2
Input 2 configuration
UIN 3
input3
Input 3 configuration
msg_comp_acc_eco
max_speed: Max speed
time_shift: Time shift
Message Composition: Basics
msg_comp_basics
gsm_level: GSM Level
dev_status1: Device Status 1
dev_status2: Device Status 2
ext_voltage: External voltage
int_voltage: Internal voltage
msg_comp_io
ain1: Analog input 1
ain2: Analog input 2
ain3: Analog input 3
inp_line: Input line 1-8
out_line: Output line 1-8
eng_hours: Engine hours
msg_comp_navigation
alt: Altitude
lbs: LBS
coord: Coordinates
course: Course
mileage: Mileage
hdop_pdop: HDOP/PDOP
inter_mileage: Inter mileage
Tracking
new_point
New track points conditions
angle: On Direction Change
timer: On Timer
distance: On Distance
over_speed: On Over Speed
RCS Connect
ntc_connect
ip: RCS IP
port: RCS Port
session_id: Session ID
Line 1
Output 1 configuration
out: Use As
reset_delay: Reset Delay
Line 2
Output 2 configuration
out: Use As
Activate/Deactivate Output
output_state
Activate or deactivate output
line: Output
state: State
Reboot the device.
RFU Connect
rfu_connect
ip: RFU IP
port: RFU Port
firmware: Firmware
tm_delays
on_delay: On Delay
{"text":"*?S"}
{"text":"*!SETOUT 1Y,2N"}
{"text":"*?V"}
Set output line state
output
Set output line 1...4 state
line: Line number
state: Line state
Turn on line 1
{"line":1,"state":true}
