Neoway T101
Neoway T101 is an LTE Cat.M1 and Cat.NB1/NB2 asset GPS tracker with extended battery life. The device features a built-in 4500mAh backup battery with life in standby mode up to 3-4 years, GNSS, Bluetooth, IP65 waterproof casing, remote configuration, and more.
Parameters (127)
Settings (8)
Neoway T101
Flespi parses telemetry data from your Neoway T101 into a standardized JSON and lets you send commands to Neoway T101 via API.
    "device.type.id": "Neoway T101",
    "protocol.id": "neoway"
How to send commands to Neoway T101?
area.alarm
Area alarm event
Message ID 0x0704
base.station.lost.alarm
Base station lost alarm event
Message ID 0x0200 with Supplementary ID 0xF6,
Message ID 0x0704 with Supplementary ID 0xF6
Message ID 0x0200 with Supplementary ID 0xF7,
Message ID 0x0211,
Message ID 0x0704 with Supplementary ID 0xF7
Message ID 0x0211,
Message ID 0x0200 with Supplementary ID 0xF8,
Message ID 0x0704 with Supplementary ID 0xF8
Message ID 0x0200 with Supplementary ID 0xF3,
Message ID 0x0211,
Message ID 0x0704 with Supplementary ID 0xF3
Message ID 0x0202,
Message ID 0x0704
bluetooth.lost.alarm
Bluetooth lost alarm event
Message ID 0x0202
Message ID 0x0202
Message ID 0x0101 with Parameter ID 0x01
Message ID 0x0900 with Transparent message 0xF5
Message ID 0x0704
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF007
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF002
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF008
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF009
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x0105
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF00A
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF004
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF005
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010C
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF001
Message ID 0x0200 with Supplementary ID 0x02,
Message ID 0x0704 with Supplementary ID 0x02
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF003
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x012F
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF006
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010F
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010B
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x0110
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x0111
Message ID 0x0200 with Supplementary ID 0x01,
Message ID 0x0704 with Supplementary ID 0x01
Message ID 0x0200 with Supplementary ID 0x03,
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010D,
Message ID 0x0704 with Supplementary ID 0x03
city.id
ID of device's home city"
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0211
Message ID 0x0704
Message ID 0x0200 with Supplementary ID 0xF2,
Message ID 0x0704 with Supplementary ID 0xF2
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
gnss.lost.alarm
GNSS lost alarm event
Message ID 0x0202,
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0101 with Parameter ID 0x02,
Message ID 0x0101 with Parameter ID 0x03,
Message ID 0x0211
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
lbs.location.precision
Precision of the location detected by base stations
Message ID 0x0211
Message ID 0x0704
manufacturer.code
Device manufacturer code"
manufacturer.device.code
mcu.version
MCU version
module.version
Module version
Message ID 0x0101 with Parameter ID 0x01,
oil.level.failure.alarm
Oil level sensor failure alarm event
Message ID 0x0704
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0900 with Transparent message 0xF1,
Message ID 0x0900 with Transparent message 0xF2
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0200 with Supplementary ID 0x31,
Message ID 0x0211,
Message ID 0x0704 with Supplementary ID 0x31
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0211
Message ID 0x0704
province.id
ID of device's home province"
Message ID 0x0211
restart.alarm
Restart alarm event
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0211
Message ID 0x0704
startup.alarm
Startup alarm event
Message ID 0x0211
Message ID 0x0704
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0900 with Transparent message 0xF3
trip.fuel.idle.consumed
Fuel consumed in the idling during the last trip
trip.max.rpm
Message ID 0x0704
Message ID 0x0704
Message ID 0x0211
Message ID 0x0211
Message ID 0x0704
wifi.lost.alarm
Wi-Fi lost alarm event
Message ID 0x0202
Message ID 0x0202
Alarm Clocks
alarm_clock
Report location data by alarm clocks
schedule: Number of Alarm Clocks
Alarms
alarms
Configure alarms
low_power: Low Power Alarm
vibration: Vibration Alarm
temperature: Temperature Alarm
tamper_proof: Tamper Proof Alarm
Configure
configure
Update device configuration
fix_interval: GPS Fix Interval
report_interval: Send Report Interval
Firmware Upgrade
init_fw_upgrade
Initiate firmware upgrade process for the device
url: URL Address
type: Upgrade type
timer: Timer
manufacturer_id: Manufacturer ID
Network access configuration
Periodic Report
periodic_report
Report location data periodically
Periodic Tracking
periodic_tracking
Fix device position periodically
Backend Server
Switch device to the specified backend server host:port
param: Parameter number
