Neoway T201
Neoway T201 is an LTE Cat.M1 and Cat.NB1/NB2 vehicle GPS tracker. The device features driving behavior analysis, wide input voltage range, built-in HPC backup battery, GNSS, Bluetooth, IP65 waterproof casing, remote configuration, 150mAh backup battery, and more.
Parameters (127)
Settings (10)
Neoway T201
Flespi parses telemetry data from your Neoway T201 into a standardized JSON and lets you send commands to Neoway T201 via API.
    "device.type.id": "Neoway T201",
    "protocol.id": "neoway"
How to send commands to Neoway T201?
area.alarm
Area alarm event
Message ID 0x0704
base.station.lost.alarm
Base station lost alarm event
Message ID 0x0200 with Supplementary ID 0xF6,
Message ID 0x0704 with Supplementary ID 0xF6
Message ID 0x0200 with Supplementary ID 0xF7,
Message ID 0x0211,
Message ID 0x0704 with Supplementary ID 0xF7
Message ID 0x0211,
Message ID 0x0200 with Supplementary ID 0xF8,
Message ID 0x0704 with Supplementary ID 0xF8
Message ID 0x0200 with Supplementary ID 0xF3,
Message ID 0x0211,
Message ID 0x0704 with Supplementary ID 0xF3
Message ID 0x0202,
Message ID 0x0704
bluetooth.lost.alarm
Bluetooth lost alarm event
Message ID 0x0202
Message ID 0x0202
Message ID 0x0101 with Parameter ID 0x01
Message ID 0x0900 with Transparent message 0xF5
Message ID 0x0704
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF007,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF007
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF002,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF002
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF008,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF008
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF009,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF009
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x0105,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x0105
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF00A,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF00A
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF004,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF004
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF005,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF005
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010C,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x010C
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF001,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF001
Message ID 0x0200 with Supplementary ID 0x02,
Message ID 0x0704 with Supplementary ID 0x02
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF003,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF003
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x012F,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x012F
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0xF006,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0xF006
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010F,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x010F
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010B,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x010B
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x0110,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x0110
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x0111,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x0111
Message ID 0x0200 with Supplementary ID 0x01,
Message ID 0x0704 with Supplementary ID 0x01
Message ID 0x0200 with Supplementary ID 0x03,
Message ID 0x0200 with Supplementary ID 0xF4 with OBD function ID 0x010D,
Message ID 0x0704 with Supplementary ID 0x03,
Message ID 0x0704 with Supplementary ID 0xF4 with OBD function ID 0x010D
city.id
ID of device's home city"
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0211
Message ID 0x0704
Message ID 0x0200 with Supplementary ID 0xF2,
Message ID 0x0704 with Supplementary ID 0xF2
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
gnss.lost.alarm
GNSS lost alarm event
Message ID 0x0202,
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211
Message ID 0x0101 with Parameter ID 0x02,
Message ID 0x0101 with Parameter ID 0x03,
Message ID 0x0211
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
lbs.location.precision
Precision of the location detected by base stations
Message ID 0x0211
Message ID 0x0704
manufacturer.code
Device manufacturer code"
manufacturer.device.code
mcu.version
MCU version
module.version
Module version
Message ID 0x0101 with Parameter ID 0x01,
oil.level.failure.alarm
Oil level sensor failure alarm event
Message ID 0x0704
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0211
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0900 with Transparent message 0xF1,
Message ID 0x0900 with Transparent message 0xF2
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0200 with Supplementary ID 0x31,
Message ID 0x0211,
Message ID 0x0704 with Supplementary ID 0x31
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0211,
Message ID 0x0704
Message ID 0x0211
Message ID 0x0704
province.id
ID of device's home province"
Message ID 0x0211
restart.alarm
Restart alarm event
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
Message ID 0x0211
Message ID 0x0704
startup.alarm
Startup alarm event
Message ID 0x0211
Message ID 0x0704
Message ID 0x0704
Message ID 0x0202,
Message ID 0x0211,
Message ID 0x0900 with Transparent message 0xF3
trip.fuel.idle.consumed
Fuel consumed in the idling during the last trip
trip.max.rpm
Message ID 0x0704
Message ID 0x0704
Message ID 0x0211
Message ID 0x0211
Message ID 0x0704
wifi.lost.alarm
Wi-Fi lost alarm event
Message ID 0x0202
Message ID 0x0202
GPRS access point configuration
Server Setup
Backend server setup
Default Interval
default_interval
Default report interval
Heartbeat Interval
heartbeat
Device heartbeat interval
Firmware Upgrade
init_upgrade
Initiate firmware upgrade process for the device
target: Upgrade Unit
upgrade: Upgrade Method
Reset Device
Shutdown Device
shutdown
Sleep Mode Interval
sleep_interval
Report interval in sleep mode
TCP Interval
tcp_interval
Timeout interval of TCP messages
TCP Retransmissions
tcp_retransmissions
The number of TCP retransmissions
count: Retransmission Count
param: Parameter number
