Okai ES400B
Okai ES400B belongs to the first generation of scooters with external power exchange. It comes with a patented 4th generation IoT module and GPS/GLONASS/BDS geolocation. It is IP67 rated and offers geofence functions, self-diagnostics, and multiple safety alerts.
Parameters (129)
Settings (23)
Okai ES400B
Flespi parses telemetry data from your Okai ES400B into a standardized JSON and lets you send commands to Okai ES400B via API.
    "device.type.id": "Okai ES400B",
    "protocol.id": "okai"
How to send commands to Okai ES400B?
alive.status
backup.battery.status
Backup battery usage status
battery.lock.firmware.version
Battery lock firmware version
battery.lock.hardware.version
Battery lock hardware version
battery.lock.position.status
Battery lock position status
battery.pack.number
battery.parallel.number
battery.serial
Scooter battery serial number
battery.series.number
Number of batteries in series
bluetooth.unlock.password
Bluetooth unlock password
can.rx.error.count
can.tx.error.count
condition.limit
device.reboot
Device reboot status
ecu.battery.charging.status
ecu.battery.lock.door.status
ecu.battery.lock.status
ecu.bell.button.status
ecu.charging.status
ecu.error.code
ECU error code
ecu.error.type
ECU error type
ecu.hardware.version
ECU hardware version
ecu.head.light.status
ecu.key.status
ecu.rear.light.status
ecu.remaining.mileage
ecu.ride.time
Time of riding read from ECU
ecu.speed
Current speed read from ECU
ecu.total.mileage
Total mileage read from ECU
error.event.status
Error event status
frames.count
gps.module.version
GPS module version
helmet.box.door.status
Helmet box door opened status
helmet.box.lock.status
Helmet box locked status
helmet.exists.status
Helmet exists status
helmet.id
Helmet ID
helmet.recognition.status
horseshoe.lock.status
Horseshoe lock status
iot.error.code
left.brake
Left brake value
lock.failure.alarm
Locking failure alarm event
max.battery.temperature
Maximum battery temperature
mechanical.lock.event
Mechanical lock event type
mechanical.lock.status
mechanical.lock.type
Type of mechanical lock
min.battery.temperature
Minimum battery temperature
motion.data.count
Motion data samples count
mqtt.will.message
MQTT Will message
nfc.code
NFC card code (UID)
peak.battery.current
Peal battery current
pile.lock.firmware.version
Pile lock firmware version
pile.lock.hardware.version
Pile lock hardware version
pile.lock.status
Pile lock status
qr.code
QR code of the device
right.brake
Right brake value
scooter.firmware.version
Scooter firmware version
scooter.hardware.version
Scooter hardware version
spare.lock.firmware.version
Spare lock firmware version
spare.lock.hardware.version
Spare lock hardware version
speed.handle
Speed handle value
task.code
Task code
Battery Lock
battery_lock
Lock/unlock the battery lock
state: Lock
Electronic Bell
electronic_bell
Play the electronic bell audio
Fixed Report
fixed_report
Configuration of fixed report GTFRI
mode: Enable
without_gps: Report Without GPS
lock_interval: Lock Send Interval
backup_interval: Backup Battery Interval
unlock_interval: Unlock Send Interval
gps_optimization: Enable GPS Optimization
Continuous Vibration Alarm
gtalm
six_axis_sensor: Six-axis sensor direction
continuous_vibration_alarm: Continuous vibration alarm
Battery Manager Information
gtbmi
mode: Report Mode enable
lock_send_interval: Lock send interval
unlock_send_interval: Unlock send interval
Scooter initialization Configuration
gtcic
push_mode: Push mode
motor_lock: Moror lock
ecu_throttle: ECU throttle
parking_gear: Parking gear
overspeed_alarm: Overspeed alarm
wireless_charging: Wireless charging
dashboard_charging: Dashboard charging auto off time
ECU Parameters Configuration
gtecc
mode: Speed up mode
brake_force: Brake force
speed_limit: Maximum speed limit
display_unit: Display unit
rear_lamp_mode: Rear lamp working mode
keenetic_recovery_level: Kinetic energy recovery level
Network Configuration
gtqss
host: Main Server IP/Domain Name
port: Main Server Port
region: Region
lte_mode: LTE mode
heartbeat: Enable heartbeat
enable_sack: Enable SACK
report_mode: Report mode
apn_password: APN password
apn_username: APN username
network_mode: Network mode
enable_buffer: Enable buffer
enable_ble_unlock: Enable BLE Unlock
ble_broadcast_name: BLE Broadcast name
Mode switch
gtxwm
mode: Working mode
test_mode_usb: Report to USB debug channel in test mode
normal_mode_usb: Report to USB debug channel in normal mode
test_mode_server: Report to server in test mode
normal_mode_server: Report to server in normal mode
test_mode_bluetooth: Report to Bluetooth in test mode
normal_mode_bluetooth: Report to Bluetooth in normal mode
Turn off the head lamp
hloff
Turn on the head lamp
hlon
LED
led
rgb: RGB ambient lighting
status: Status light
headlight: Headlight auto on/off
turn_signal: Turn signal
center_console: Center console LED
animation_interval: Animation interval
Lock the ECU Lock
lock
Power Off
power_off
Power off the device remotely
Reboot the device remotely
Turn off the rear lamp
rloff
Turn on the rear lamp (even if the ECU-Lock is locked)
rlonen
Turn off the throttle
spdoff
Turn on the throttle
spdon
Two-person detection
tpt
mode: Two-person detection enable
exit_time: Exit two-person detection time
speed_limit: Speed limit during two-person riding
trigger_time: Two-person detection trigger time
Unlock the mechanical lock
ulkmec
type: Mechanical-Lock type
Unlock the ECU Lock
unlock
Illegal use of scooter warning
warn
AT Command
password: Device password
{"cmd":"GTRTO","payload":"3,,,0,,,,","password":"mypass"}
