Ruptela FM-Eco4+ light 3G T
Ruptela FM-Eco4+ light 3G T is a tracking device (3G/2G) with a regular casing, small size, and internal antennas. The device features 4 digital inputs, 2 analog inputs, 2 digital outputs, 1-Wire interface, 3-axis accelerometer, sleep mode and deep sleep mode, and more.
Parameters (526)
Settings (39)
Flespi parses telemetry data from your Ruptela FM-Eco4+ light 3G T into a standardized JSON and lets you send commands to Ruptela FM-Eco4+ light 3G T via API.
    "device.type.id": "Ruptela FM-Eco4+ light 3G T",
    "protocol.id": "ruptela"
How to send commands to Ruptela FM-Eco4+ light 3G T?
Command ID 0x23
accelerometer.data.seqnum
Command ID 0x23
adas.alert.id
adas.fatigue.alert
adas.snapshots.count
adas.snapshot.source
adas.snapshot.timestamp
Command ID 0x44 with IO ID 23
ain.event
AIN event
antihijack.bitmask
Antihijack status bitmask
auto.geofence.alert
Auto-geofence alert
Command ID 0x44 with IO ID 30
ble.asset.battery.level
ble.asset.battery.voltage
Command ID 0x26
ble.sensor.status
ble.sensor.value
calibration.matrix.index
Command ID 0x23
can.air.suspension.control
can.alternator.error
can.alternator.status
Command ID 0x44 with IO ID 97
can.configuration.bitmask
Command ID 0x44 with IO ID 37
can.diagnostic.support.enum
Command ID 0x44 with IO ID 93
Command ID 0x09
can.dtc.indication.lights
Command ID 0x44 with IO ID 96
Command ID 0x44 with IO ID 94
can.first.driver.card.id
CAN first driver ID
can.fms.axle.location.enum
can.fms.tire.location.enum
Command ID 0x44 with IO ID 90
Command ID 0x44 with IO ID 98
Command ID 0x44 with IO ID 99
can.j1939.cargo.weight
CAN J1939 cargo weight
can.j1939.trailer.weight
CAN J1939 trailer weight
can.left.front.tire.pressure
can.left.rear.tire.pressure
LVC control state flags
can.manufacturer.enum
can.movement.status
Command ID 0x44 with IO ID 13
CAN at least one PTO engaged
Command ID 0x44 with IO ID 91
Command ID 0x44 with IO ID 38
can.request.support.enum
can.retarder.selection
can.retarder.torque.mode
can.right.front.tire.pressure
can.right.rear.tire.pressure
can.secondary.driver.card.id
CAN second driver ID
can.secondary.fuel.level
can.system.event.enum
CAN system event enum
Command ID 0x44 with IO ID 42
can.tacho.driver.card.enum
can.tacho.driver.time.enum
Command ID 0x44 with IO ID 16
Command ID 0x44 with IO ID 43
can.tacho.overspeeding.event
CAN tacho vehicle overspeed
can.tacho.performance.enum
CAN tachograph performance
CAN tacho direction indicator
Command ID 0x44 with IO ID 44
can.vehicle.battery.capacity
can.vehicle.id
CAN vehicle ID
config.engine.ignition.status
counter.din.cumulative.hours
counter.din.hours
counter.fuel.value
Fuel counter
crash.impact.direction
Crash impact direction
Command ID 0x23
Command ID 0x44 with IO ID 28
Command ID 0x01 with IO ID 6,
din.high.event
DIN high event
din.low.event
DIN low event
driver.registration.status
Driver registration status
ds1971.driver.ibutton.code
dtc.latitude
Command ID 0x09
dtc.longitude
Command ID 0x09
dtc.source
Command ID 0x09
dtc.status
Command ID 0x09
dtc.timestamp
Command ID 0x09
eco.driving.pedal.fuel.ranges
eco.driving.rpm.fuel.ranges
ECO RPM fuel used ranges
eco.driving.stops.count
ECO Number of vehicle stops
eco.engine.braking.distance
ECO engine braking distance
event.id
Command ID 0x01,
Command ID 0x44
Command ID 0x01,
Command ID 0x44
external.powersource.current
External supply current
extnav.position.altitude
fuel.sensor.a1.temperature
fuel.sensor.a1.value
fuel.sensor.b1.temperature
fuel.sensor.b1.value
Command ID 0x44 with IO ID 67
fuel.sensor.c10.temperature
fuel.sensor.c10.value
fuel.sensor.c1.temperature
Command ID 0x44 with IO ID 56
fuel.sensor.c1.value
Command ID 0x44 with IO ID 66
fuel.sensor.c2.temperature
fuel.sensor.c2.value
Command ID 0x44 with IO ID 68
fuel.sensor.c3.temperature
fuel.sensor.c3.value
Command ID 0x44 with IO ID 69
fuel.sensor.c4.temperature
fuel.sensor.c4.value
Command ID 0x44 with IO ID 81
fuel.sensor.c5.temperature
fuel.sensor.c5.value
Command ID 0x44 with IO ID 82
fuel.sensor.c6.temperature
Command ID 0x44 with IO ID 61
fuel.sensor.c6.value
Command ID 0x44 with IO ID 83
fuel.sensor.c7.temperature
fuel.sensor.c7.value
Command ID 0x44 with IO ID 84
fuel.sensor.c8.temperature
fuel.sensor.c8.value
fuel.sensor.c9.temperature
fuel.sensor.c9.value
Command ID 0x44 with IO ID 86
fuel.sensor.frequency
DUT-E S7 frequency
garmin.payload.hex
Garmin payload in hex
Command ID 0x1F
garmin.status
Garmin FMI module status
Command ID 0x1E
geofence.group.id
Geofence group ID
geofence.valid
Geofence reliablity flag
gnss.antenna.type
gnss.fix.duration
Command ID 0x07
Command ID 0x44 with IO ID 88
Command ID 0x0F,
Command ID 0x0F,
Command ID 0x0F,
Command ID 0x44 with IO ID 27
Command ID 0x0F
gsm.state.enum.description
gsm.troublecode.bitmask
image.count
image.status
iqfreeze.ain
iqfreeze.ain.error
iQFreeze analog input error
iqfreeze.battery.voltage
iqfreeze.cycle.mode
iqfreeze.din
iQFreeze digital inputs
iqfreeze.door.status
iqfreeze.electric.hours
iqfreeze.engine.hours
iqfreeze.engine.rpm
iqfreeze.error
iQFreeze error number
iqfreeze.errors.number
iqfreeze.operating.mode
iqfreeze.refrigerator.enum
iqfreeze.setpoint
iqfreeze.temperature
iqfreeze.timestamp
iqfreeze.vehicle.hours
magnetic.card.code
Magnetic Card ID code
ot.din
OT digital input value
ot.sensor.temperature
OT Temperature sensor value
passenger.ibutton.code
iButton code of passenger
Command ID 0x0E
port.id
Command ID 0x0E
Command ID 0x01,
Command ID 0x07,
Command ID 0x44
Command ID 0x01,
Command ID 0x07,
Command ID 0x44
Command ID 0x01,
Command ID 0x07,
Command ID 0x44
Command ID 0x01,
Command ID 0x07,
Command ID 0x23,
Command ID 0x26,
Command ID 0x44
Command ID 0x01,
Command ID 0x07,
Command ID 0x23,
Command ID 0x26,
Command ID 0x44
Command ID 0x01,
Command ID 0x07,
Command ID 0x44
Command ID 0x01,
Command ID 0x23,
Command ID 0x44,
Command ID 0x07
Command ID 0x01,
Command ID 0x44
refrigerator.engine.mode
refrigerator.engine.mode.enum
Fridge high speed status
refrigerator.operate.mode
refrigerator.operating.mode
refrigerator.set.temperature
rollover.alarm.status
Roll over alarm state
sdcard.log.enum
SD card log id
sdcard.log.marker.value
SD Log record Marker
security.event.enum
Security information ID
segment.acceleration.events
segment.ain.voltage
segment.braking.distance
segment.braking.duration
segment.braking.events
segment.cornering.events
segment.engine.on.time
segment.free.rolling.distance
segment.fuel.idle.used
segment.harsh.braking.events
segment.highest.gear.distance
segment.max.engine.rpm
Maximum engine RPM on segment
segment.normal.speed.distance
segment.overspeeding.distance
segment.overspeeding.time
segment.rpm.green
segment.rpm.range.distance
segment.rpm.range.fuel.used
segment.rpm.red
segment.rpm.red.distance
sensor.frequency
Frequency sensor value
sensor.state.bitmask
sensor.temperature.error
Temperature sensor error code
shock.duration
Duration of shock
sleep.timer.wakeup.status
Device wake-up by timer event
spreader.mode
Spreader mode
tacho.card.reader.status
Tacho card reader state
Command ID 0x44 with IO ID 24
Driver time states
tacho.engine.rpm
Engine RPM reported by tacho
tacho.fms.driver.id
tacho.fms.driver.status.enum
tacho.registration.code
Tacho registration number
tacho.vehicle.id
CAN tachograph vehicle ID
Command ID 0x01,
Command ID 0x05,
Command ID 0x0B,
Command ID 0x0E,
Command ID 0x23,
Command ID 0x26,
Command ID 0x44
Command ID 0x01,
Command ID 0x23,
Command ID 0x44
tire.pressure.bitmask
total.idle.time
trailer.braking.wheel.speed
trailer.state.bitmask
Trailer status
trailer.tire.pressure
Trailer tires pressure
trailer.vin
Trailer VIN
trailer.wireless.id
Trailer wireless ID
trip.type
Trip type (Private, Business)
ubi.process.status
UBI data saving is in process
umts.enabled
UMTS enabled
wireless.enabled
Wireless enabled
wireless.pair.status
Wireless Pair
x.axis.angle
X-axis angle to horizon
y.axis.angle
Y-axis angle to horizon
z.axis.angle
Z-axis angle to horizon
accelerometer_info
xc: Xc
yc: Yc
zc: Zc
xyzo: XYZo
state: Calibration State
CAN Autoconfiguration Info
can_autoconfig_info
can1: CAN1
can2: CAN2
autocfg: Autoconfiguration
CAN1 Interface Info
can_info
mode: CAN Mode
active: Active Mode
lcv_group: LCV Group
manufacturer: Manufacturer
Coefficients
coefficients1
radial: Radial
distance: Distance
Coefficients
coefficients2
radial: Radial
distance: Distance
Coefficients
coefficients3
radial: Radial
distance: Distance
Coefficients
coefficients4
radial: Radial
distance: Distance
Connection data
connection
Connection data
server: Server
protocol: Protocol
constant_link1
heartbeat: Enable heartbeat
constant_link2
constant_link3
constant_link4
Get GPS
coords
Data collection
data_collection1
engine: Engine
Data collection
data_collection2
engine: Engine
Data collection
data_collection3
engine: Engine
Data collection
data_collection4
engine: Engine
Data sending
data_sending1
period: Period
min_records: Min records
link_timeout: Link timeout
Data sending
data_sending2
period: Period
Data sending
data_sending3
period: Period
Data sending
data_sending4
period: Period
Delete all records
delrecords
doutreset
Dynamic Identification
dynamic_identification
imsi: IMSI
cfg_tag: CFG Tag
boot_ver: Bootloader Version
dev_type: Device Type
angl_coef: Angle Coefficient
time_coef: Time Coefficient
ocsp_status: OCSP Status
gsm_operator: GSM Operator
eco_acceleration
ECO-drive: Braking limit
eco_braking
ECO-drive: Cornering limit
eco_cornering
limit: Cornering limit
Eco-drive: Idling
eco_idling
idling_delay: Idling delay
idling_speed: Idling speed
econnect
ip: IP Address
apn_name: APN Name
protocol: Protocol
apn_login: APN Login
apn_password: APN Password
ECO-drive: Overspeeding limit
eco_overspeeding
limit: Overspeeding limit
Static Identification
identification
imsi: IMSI
device_type: Device Type
Immobilize the vehicle
immobilizer
Locks Info
lock_info
ip_lock: IP Lock
apn_lock: APN Lock
pin_code: SIM PIN Code
sim_lock: SIM Lock
port_lock: Port Lock
Set odometer value
value: Odometer value
Reset Device
Reset (reboot) the device
resetimmob
Setio
setio2
dout1: Dout 1
dout2: Dout 2
Setiotime
setiotime2
dout1: Dout 1
dout2: Dout 2
command_id: Command ID
Send Data to Germin Device
Get Status of Garmin Device
Send data over Serial port
