You can obtain telematics data from any Ruptela device in 6 easy steps:
Set up the Ruptela channel in your flespi.io interface.
Point a Ruptela device to your channel using the device configurator from Ruptela or by sending an SMS command to the device.
Access Ruptela device data via API.
2. Set up the Ruptela channel on flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “ruptela” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Ruptela device to your flespi channel
You can do it with Ruptela's Advanced Configurator tool, Device Center, or by sending an SMS command to the device. Domain name and port to point the device to are shown in the channel box.
The syntax of the SMS command is as follows:
pass setcfg 110 domain, 120 port
where
pass — configuration password if used,
setcfg — command used to upload configuration parameters,
110 — parameter number for IP1,
120 — parameter number for Port1.
While in the Channel dialogue box, click on the Logs & Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Ruptela device data via API
Make a note of your Channel ID and click on the API Playground menu item in the lower left corner:
6. Create a flespi device
What's next?
