Sunlab (Suntech) ST4280
Sunlab ST4280 is IP67-rated GPS asset tracking device with a magnetic mount, designed for versatile asset tracking applications such as trailer, container, vehicle, and motorcycle locating. It supports 4G LTE-Cat M1/GPRS connectivity, BLE, and Wi-Fi access points scanning for indoor location. Equipped with a 6-axis accelerometer, and a high-capacity 17 Ah battery, the ST4280 is optimized for low power consumption, making it ideal for long-term usage.
Parameters (286)
Flespi parses telemetry data from your Sunlab (Suntech) ST4280 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4280 via API.
    "device.type.id": "Sunlab (Suntech) ST4280",
How to send commands to Sunlab (Suntech) ST4280?
OBD PID 52
ALT Report Header 24,
OBD PID 43
OBD PID 4A
ALT Report Alert ID 71
OBD PID 33
OBD PID 3F
OBD PID 2C
OBD PID 42
OBD PID 41
OBD PID 23
OBD PID 4E
OBD PID 30
OBD PID 2D
OBD PID 1F
OBD PID 44
OBD PID 2E
OBD PID 32
OBD PID 51
OBD PID 0F
OBD PID 0B
OBD PID 10
OBD PID 50
OBD PID 21
OBD PID 4D
OBD PID 3B
OBD PID 3B
OBD PID 1B
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 1B
OBD PID 2B
OBD PID 22
OBD PID 45
OBD PID 12
OBD PID 58
OBD PID 57
OBD PID 4C
OBD PID 48
OBD PID 0E
