ALT Report Header 24,
*major* - iBeacon Major value
*minor* - iBeacon Minor value
*code* - Trouble code, e.g. P0100 (OBDII)
*extension* - Failure type byte of the trouble code in hex (OBDII)
*protocol* - Diagnostic protocol the code was read with (OBD, J1939, J1708, UDS, KWP2000)
ALT Report Alert ID 20,
ALT Report Alert ID 22
