Sunlab (Suntech) ST4950
Suntech ST4950 is a powerful solar GPS tracker for logistics management, monitoring the cold/supply chain, agriculture, construction with trailers, containers, and other assets. The device features LTE Cat M1/NB-IoT connectivity, solar panel, 1-Wire for a temperature sensor, 5,200mAh battery, IP67 compliant casing, and more.
Parameters (318)
Flespi parses telemetry data from your Sunlab (Suntech) ST4950 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST4950 via API.
    "device.type.id": "Sunlab (Suntech) ST4950",
How to send commands to Sunlab (Suntech) ST4950?
