Sunlab (Suntech) ST630
Suntech STU630 is a compact and standalone 3G GPS tracker for trailers with hibernation function. The device features 3-axis accelerometer, anti-theft alert, geo-fencing, route deviation, travel distance, IP67 casing (with fixing holder/magnetic buttons), 5200mAh Li-Ion battery, and more.
Parameters (318)
Settings (9)
Flespi parses telemetry data from your Sunlab (Suntech) ST630 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST630 via API.
    "device.type.id": "Sunlab (Suntech) ST630",
How to send commands to Sunlab (Suntech) ST630?
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Output 4
output4
Enable/disable output 4
Reboot device
Report Parameters
reporting
Report generation parameters
status
