Sunlab (Suntech) ST300B
Suntech ST300B is a basic GPS tracker supporting communication over TCP and UDP. The device features driving pattern analysis, 3-axis accelerometer, ignition status, panic button, backup battery, jamming detection, geo-fencing, FOTA, and more.
Parameters (303)
Settings (8)
Flespi parses telemetry data from your Sunlab (Suntech) ST300B into a standardized JSON and lets you send commands to Sunlab (Suntech) ST300B via API.
    "device.type.id": "Sunlab (Suntech) ST300B",
How to send commands to Sunlab (Suntech) ST300B?
ALT Report Header 24,
Standard parameter names used: *id* - beacon identification string. Usually it is beacon's UUID or MAC-address *local_name* - Beacons's Local Name *rssi* - BLE signal level. Units = dBm *battery.voltage* - Beacon's battery voltage. Units = volts *battery.voltage.volts* - Beacon's battery voltage in volts (transition field, will be removed after 2026-05-19) *battery.level* - Beacon's battery level. Units = percentage *temperature* - Beacon's temperature. Units = celsius
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Reboot device
Report Parameters
reporting
Report generation parameters
status
