Sunlab (Suntech) ST300C
Suntech ST300C is a high-end GPS tracker with CANbus interface supporting communication over TCP and UDP. The device features driving pattern analysis, 3-axis accelerometer, backup battery, analog input, jamming detection, geo-fencing, FOTA, and more.
Parameters (297)
Settings (8)
Flespi parses telemetry data from your Sunlab (Suntech) ST300C into a standardized JSON and lets you send commands to Sunlab (Suntech) ST300C via API.
    "device.type.id": "Sunlab (Suntech) ST300C",
How to send commands to Sunlab (Suntech) ST300C?
ALT Report Header 24,
ALT Report Alert ID 71
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Reboot device
Report Parameters
reporting
Report generation parameters
status
