Sunlab (Suntech) ST300H
Suntech ST300H is a high-end GPS tracker supporting communication over TCP and UDP. The device features driving pattern analysis, 3-axis accelerometer, overspeeding alarm, backup battery, jamming detection, geo-fencing, FOTA, and more.
Parameters (287)
Settings (8)
Flespi parses telemetry data from your Sunlab (Suntech) ST300H into a standardized JSON and lets you send commands to Sunlab (Suntech) ST300H via API.
    "device.type.id": "Sunlab (Suntech) ST300H",
How to send commands to Sunlab (Suntech) ST300H?
OBD PID 52
ALT Report Header 24,
OBD PID 43
OBD PID 4A
ALT Report Alert ID 71
OBD PID 33
OBD PID 3F
OBD PID 2C
OBD PID 42
OBD PID 41
OBD PID 23
OBD PID 4E
OBD PID 30
OBD PID 2D
OBD PID 1F
OBD PID 44
OBD PID 2E
OBD PID 32
OBD PID 51
OBD PID 0F
OBD PID 0B
OBD PID 10
OBD PID 50
OBD PID 21
OBD PID 4D
can.monitor.status
Monitor status this drive cycle read from CAN, bitmask
OBD PID 41
OBD PID 3B
OBD PID 3B
OBD PID 1B
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 4F
OBD PID 1B
OBD PID 2B
OBD PID 22
OBD PID 45
OBD PID 12
OBD PID 58
OBD PID 57
OBD PID 4C
OBD PID 48
OBD PID 0E
can.trip.engine.motorhours
Hour Meter
hour_meter
Set travelled time
value: Hour-Meter
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
value: Distance
Reboot device
Report Parameters
reporting
Report generation parameters
status
