Sunlab (Suntech) ST330
Suntech ST330 is a compact vehicle GPS tracker with IP67 casing. The device features built-in 3-axis accelerometer, RS232 port, 3 inputs, 1 output, 5200 mAh Li-Ion battery, anti-theft, geofencing, and more.
Parameters (309)
Settings (5)
Flespi parses telemetry data from your Sunlab (Suntech) ST330 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST330 via API.
    "device.type.id": "Sunlab (Suntech) ST330",
How to send commands to Sunlab (Suntech) ST330?
ALT Report Header 24,
trip.engine.motorhours.hours
Temporary parameter previewing the corrected hours value of trip.engine.motorhours on suntech and queclink; removed once trip.engine.motorhours is corrected to hours
auth: Auth
host_backup: Secondary host
port_backup: Secondary port
Report Parameters
reporting
Report generation parameters
status
