Sunlab (Suntech) ST3300
Suntech ST3300 is a 3G GPS tracker suited for high-valued standing and mobile assets like trailers, containers, trains, and yachts. The device features a 3-axis accelerometer, 1-Wire, RS232, ignition input, 3 additional inputs, 3 outputs, 450mAh Ni-MH battery, and more.
Parameters (303)
Flespi parses telemetry data from your Sunlab (Suntech) ST3300 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST3300 via API.
    "device.type.id": "Sunlab (Suntech) ST3300",
How to send commands to Sunlab (Suntech) ST3300?
ALT Report Header 24,
Standard parameter names used: *id* - beacon identification string. Usually it is beacon's UUID or MAC-address *local_name* - Beacons's Local Name *rssi* - BLE signal level. Units = dBm *battery.voltage* - Beacon's battery voltage. Units = volts *battery.voltage.volts* - Beacon's battery voltage in volts (transition field, will be removed after 2026-05-19) *battery.level* - Beacon's battery level. Units = percentage *temperature* - Beacon's temperature. Units = celsius
