Sunlab (Suntech) ST3310
Suntech ST3310 is a low-cost, compact-size, water-resistant GPS tracker. The device features RS232, 1-Wire, 220mAh Li-ion battery, IP67-compliant casing, geofencing, jamming detection, configurable report formats, and more.
Parameters (303)
Settings (5)
Flespi parses telemetry data from your Sunlab (Suntech) ST3310 into a standardized JSON and lets you send commands to Sunlab (Suntech) ST3310 via API.
    "device.type.id": "Sunlab (Suntech) ST3310",
How to send commands to Sunlab (Suntech) ST3310?
ALT Report Header 24,
